My domain is: virtualyou.io
I ran this command: sudo ./init-letsencrypt
Domain: virtualyou.io
Type: connection
Detail: Fetching
http://virtualyou.io/.well-known/acme-challenge/_sSXGkTrTGR3vwa-dEKvG-8BweRsOQRzPVym8jaT5CM:
Connection refusedTo fix these errors, please make sure that your domain name was
that you are serving files from the webroot path you provided. -
Your account credentials have been saved in your Certbot
making regular backups of this folder is ideal. -
We were unable to subscribe you the EFF mailing list because your
e-mail address appears to be invalid. You can try again later by
visiting https://act.eff.org.
Reloading nginx …
ERROR: No container found for nginx_1
The operating system my web server runs on is (include version): Debian 9
My hosting provider, if applicable, is: Digital Ocean
Can login to a root shell on my machine (yes or no, or I don’t know): Yes
or certbot-auto --version
if you’re using Certbot): Certbot Docker image
NOTES: I’ve run the init-letsencrypt.sh script prior to fixing my docker-compose.yml with commands to auto-renew using domain abc.ciwise.com … I changed the app everywhere to virtualyou.io . I suspect you (Letsencrypt) still have my certificate request for another machine (earlier) that was an Apache web server for static hosting. I deleted my DNS records for abc.ciwise.com and created new for virtualyou.io. So I had to revise everything from abc.ciwise.com to virtualyou.io and do the chicken-egg thing with the script to get the cert going. I do know that iptables get’s modified automatically with Docker so that could very well be the “connection” issue back to letsencrypt.org
