Trouble using certbot with nginx on docker
My domain is: cpc.saipathuri.me
docker run -it --rm
-v certs:/etc/letsencrypt
-v certs-data:/data/letsencrypt
deliverous/certbot
certonly
--staging
--webroot --webroot-path=/data/letsencrypt
-d cpc.saipathuri.me
which is certbot certonly --staging --webroot --webroot-path=/data/letsencrypt -d cpc.saipathuri.me
    /usr/local/lib/python2.7/site-packages/josepy/jwa.py:107: CryptographyDeprecationWarning: signer and verifier have been deprecated. Please use sign and verify instead.
      signer = key.signer(self.padding, self.hash)
    http-01 challenge for cpc.saipathuri.me
    Using the webroot path /data/letsencrypt for all unmatched domains.
    Failed authorization procedure. cpc.saipathuri.me (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://cpc.saipathuri.me/.well-known/acme-challenge/ICJP8LP-i23YkwaLUIVC272cRJTsdToJLDtc2fUGoJE: "<html>
    <head><title>404 Not Found</title></head>
    <body bgcolor="white">
    <center><h1>404 Not Found</h1></center>
    <hr><center>"
   Domain: cpc.saipathuri.me
   Type:   unauthorized
   Detail: Invalid response from
   "<html>
   <hr><center>"
The operating system my web server runs on is (include version): docker
My hosting provider, if applicable, is: AWS EC2
I am able to access the /.well-known/acme-challenge directory (http://cpc.saipathuri.me/.well-known/acme-challenge/test.txt) with a test file, but certbot keeps failing. Please help!
Hi @saipathuri,
Is this file test.txt located in /data/letsencrypt/.well-known/acme-challenge?
Hi @schoen,
Yes, it is.
After hours and hours of debugging, I figued out what the issue was. Turns out docker prepends volume names for volumes in certain situations (not sure when, I don't know enough about Docker), so the volumes created by running
docker-compose up -d
with my docker-compose file created volumes named
mysite_certs
and
mysite_certs-data
instead of
certs
and
certs-data
So I modified
docker run -it --rm
deliverous/certbot
certonly
–staging
–webroot --webroot-path=/data/letsencrypt
to be
docker run -it --rm
-v mysite_certs:/etc/letsencrypt
-v mysite_certs-data:/data/letsencrypt
deliverous/certbot
certonly
–staging
and that fixed the issue!
