If I want to activate https for both www.domain.com
or domain.com
, should I use A or CNAME record? Or what’s the best option? Because I have a CNAME, but a video tutorial recommended using A record.
Thanks,
or domain.com
Thanks,
It mostly doesn’t matter to Let’s Encrypt whether you use an A or CNAME record for a subdomain (such as www.example.com
), so it’s generally fine to use whichever one works best with the rest of your setup.
You should of course use an A and/or AAAA record for the domain apex itself (example.com
without the www
