Help! Using Let's Encrypt First Time
Hello,
As I said, I’m creating SSL for the first time. I don’t want to mess it up. It’s for a client. I saw some video tutorials, it seems very easy but many of them were very specific about adding a “non-www”, and “www” domain versions.
I’m sure my domain looks like “www.example.com”. So, is it necessary to add a “non-www” version of the domain? And if so, can I add “www” version at first then followed by a “non-www” or can I just only add “www” URL…WILL THAT MAKE A MESS?
A huge thank you in advance! :slight_smile:
It depends. (But, Yes from Let's Encrypt's side)
If you only add www.example.com, your client might be mad at you because when their customer visit example.com, they will see a full page security warning. (Same with only example.com)
It's better to use both www and root domain. Sequence doesn't matter as long as you add both in the same certificate.
