Hi All,
this was working for some time,but recently has started to fail for domain chilcote.marlinpropertydevelopment.com. Firewall is verified as open, im not sure why its saying it cant connect as NGINX is actually running. Any pointers? Thank yo!
http-01 challenge for chilcote.marlinpropertydevelopment.com
Attempting to renew cert (chilcote.marlinpropertydevelopment.com) from /etc/letsencrypt/renewal/chilcote.marlinpropertydevelopment.co m.conf produced an unexpected error: Failed authorization procedure. chilcote.marlinpropertydevelopment.com (http-01): urn:ietf:param s:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://chilcote.marlinproperty Geocentric Media: A Media, Advertising, Publishing and Software Development Company. Timeout during connect (likely firewall probl em). Skipping.
/etc/letsencrypt/live/chilcote.marlinpropertydevelopment.com/fullchain.pem (failure)
Domain: chilcote.marlinpropertydevelopment.com
Type: connection
Detail: Fetching
http://chilcote.marlinpropertydevelopment.com/.well-known/acme-challenge/xSQ801yktoanmvC4R66yRD3ghB1dAX3YXxV-liOwV7A:
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
Blockquote
all good, thanks _az!!
