A2 Hosting still does not support Lets Encrypt directly and I need to renew my cert. I got my certs to work originally, however when trying to run the command now it returns “Failed authorization procedure.”
It appears to be returning incorrect domains
Would having a dedicated IP address fully fix this issue? Or is there a way around this?
@Hexxium, take a look at the documentation at https://certbot.eff.org/ (you can try telling it that you’re using a different webserver so that you see the webroot instructions).
