Ertbot: error: unrecognized arguments: /home
I am trying to install an SSL certificate for the root domain along with a wildcard for all subdomains.
My domain is: lupitapearl.com
Webserver: Nginx
OS: Ubuntu 20.04.4
Hosting provider: GCP
Downloaded certbot using snap
Installed latest version of python3-cloudflare
$ certbot certonly --dns-cloudflare --dns-cloudflare-credentials ~/.secrets/certbot/cloudflare.ini -d lupitapearl.com -d *.lupitapearl.com –i nginx
And this output returns:
usage:
certbot [SUBCOMMAND] [options] [-d DOMAIN] [-d DOMAIN] ...
Certbot can obtain and install HTTPS/TLS/SSL certificates. By default,
it will attempt to use a webserver both for obtaining and installing the
certificate.
certbot: error: unrecognized arguments: /home/kev_m_lin/.secrets/certbot/cloudflare.ini –i nginx
Using this tutorial:
You'll need to put quotes around the wildcard:
-d "*.lupitapearl.com"
Also, did you install the Cloudflare plugin using snap?
sudo snap set certbot trust-plugin-with-root=ok
sudo snap install certbot-dns-cloudflare
Hey there - thanks for your help!
I did install that Cloudflare plug-in but I'm still getting the same error message.
It seems the dash used for the -i in front of nginx is an "en dash" (– in your post, compare that en dash with a regular one: -) and not a regular one. Did you perhaps copy/paste that -i nginx part from a how-to? You should change it to a regular dash.
Maybe even the space in front of -i is not a regular space, otherwise Certbot should see those two items separately. Better to type that space manually too before trying again.
Edit: although an unicode decoder says its a regular space.. :thinking: Not sure why Certbot doesn't see them separately in that case then..
Well spotted! The dash is definitely a problem.
Also, get rid of certonly if you want Certbot to install the certificate to nginx.
I manually input my "-" dashes and got rid of the "certonly" command. Still getting a response.
Could this be the issue? for the credentials, I input an Edit zone DNS API Token like this:
-- dns-cloudflare-credentials [API Token] ~/.secrets/certbot/cloudflare.ini
So the entire line would be:
certbot --dns-cloudflare --dns-cloudflare-credentials [API Token] ~/.secrets/certbot/cloudflare.ini -d lupitapearl.com -d "*.lupitapearl.com" -i nginx
Could I be typing out the API Token all wrong?
For context, I'm following this doc: Welcome to certbot-dns-cloudflare’s documentation! — certbot-dns-cloudflare 0 documentation
The API token goes into the .ini file. You don't include it on the command line.
Ah okay - so how do I input the API token in the .ini file?
So if you look at Welcome to certbot-dns-cloudflare’s documentation! — certbot-dns-cloudflare 0 documentation the example contents of the .ini file are:
# Cloudflare API token used by Certbot
dns_cloudflare_api_token = 0123456789abcdef0123456789abcdef01234567
You would replace 0123456789abcdef0123456789abcdef01234567 with your real API token.
Alright. I just tried this:
certbot --dns-cloudflare --dns-cloudflare-credentials [API Token] -d lupitapearl.com -d "*.lupitapearl.com" -i nginx
And got this, in dark red letters:
The following error was encountered:
[Errno 13] Permission denied: '/var/log/letsencrypt/.certbot.lock'
Either run as root, or set --config-dir, --work-dir, and --logs-dir to writeable paths.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/tmphhn1uex5/log or re-run Certbot with -v for more details.
You'll need to run Certbot as root. Use sudo certbot rather than certbot.
Keep in mind also if you stored the API credential in your non-root user's home directory, you might have to change your command to use this path:
~kev_m_lin/.secrets/certbot/cloudflare.ini
