Error timeout during connect (likely firewall problem)
My domain is: ildani.tk
I ran this command: sudo certbot certonly --standalone
Challenge failed for domain ildani.tk
http-01 challenge for ildani.tk
    Domain: ildani.tk
    Type: connection
    Detail: Fetching
    http://ildani.tk/.well-known/acme-challenge/LKcsHnVBELveU1P6wI9Hal86P1ARYvV5jneYCS9UCtI:
My web server is (include version): I am using docker.. but on port 80 there is the router server.. I can't change it
The operating system my web server runs on is (include version): debian 11
My hosting provider, if applicable, is: .tk with cloudflare
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): latest
I don't understand. Your domain points to a residential IP address, not to cloudflare.
It's fastweb, are you sure you have a public ip? (It doesnt't matter if it's static, but it needs to be public)
Most routers can forward port 80 on the external interface to a machine, if you ask them. Even if their servers are on 80 internal (some will change their port if you forward port 80).
yes I have requested it.. and it's 93.44.171.181
what do you mean point to residential ip address.. ? I have checked in cloudflare and it's setup correctly..
I have tried to forward the port 80 and 443 but doesn't work.. not sure why.. I am using a different port for my service.. 445.. and I put the server in the DMZ..
Of course it doesn't, http and https are different protocols. If you start speaking https on port 80 most people won't understand anything. (ie, all your addresses will be https://example.com:80 because you are using a non-default port)
I am not sure cloudflare likes this.
Ok, you're not using cloudflare as a cdn, just for dns. Your website is here: https://ildani.tk:445/
Validation does not work because validation needs port 80. Make your server answer on port 80 or check if the alternatives work for you (port 443, or challenge dns-01)
Just adding on that certbot does not support TLS-ALPN to use port 443 directly.
the real problem is that the port 80 (also the 443) is going to the router Fastweb setting page.. the help-desk wasn't able to disable it and release the port.. I removed to DMZ only port forwarded the port 445.. is there another way to create the cert without the port 80?
You're hosting your dns on cloudflare, you can use challenge dns-01. It's a massive overkill, though.
Are you sure you can't forward 80->80 and 443->443?
"latest" means different things to different people.
To me it means... you don't think it has anything to do with the problem - but it might.
DNS-01 authentication challenge.
Which avoids HTTP altogether.
But for that you will need a DNS Service Provider (DSP) that supports DNS zone updates via API.
And also, an ACME client that has a DNS plugin that supports your DSP.
unfortunately yes.. not sure why fastweb blocked them to the router portal.. If I port forwarding them to my server is not working.. and the help desk doesn't help..
yes right.. I don't think it's a certbot issue.. but the config of my router
If the router responds on a port, that port can't be forwarded.
The forwarding request will be ignored.
:frowning: so sad
ok DNS-01 authentican challenge I dont really think that can work with Fastweb.. can I use Cloudflare?
You can use any DNS that supports DNS updates via API.
You only need to CNAME the _acme-challenge.YOUR-DOMAIN entry.
You can even forward them to your own IP [if your ISP doesn't block TCP/UDP port 53]
but https://crt.sh/?id=6030097872 I can find the cert... why is it not loading on the website? not sure to understand it.. I have to import to my server?
That is a public cert [without the matching private key it is useless to try to encrypt & decrypt]
If it was that simple, anyone could get any cert from any site.
Also, that cert was issued by CloudFlare.
What are you trying to do?
just have a secure cert https.. I was able to setup Nginx Proxy Manager and put a CNAME in cloudflare and it's working now.. not sure why is working only with a CNAME and not to the direct A address.. thank you to all that helped me!
Yes, you can.
https://certbot-dns-cloudflare.readthedocs.io/en/stable/
Also, if you are using cloudflare as a cdn, you can get a certificate from their internal certificate authority, which only works for letting cloudflare cdn connect upstream.
And check if cloudflare cdn is ok with strange port numbers. I assume the free plan isn't.
