Error: snap "certbot-nginx" not found
sudo snap install certbot-nginx
error: snap "certbot-nginx" not found
nginx 1.14.2-2+deb10u4
Debian 10
no
This is a newly spun up x86_64 server running Debian 10. I have made sure all packages are up to date.
I created this thread separate from the other one because the environment in that thread is Arm, while mine is x86_64.
How about?:
If not, what shows?:
snap find certbot
sudo snap install certbot installed certbot successfully. It appears to be only certbot-nginx that is problematic.
Welcome to the LE community forum :slight_smile:
[better late than never - lol]
Please also show the output of (anyways to compare):
snap find certbot
Something has gone wrong with the Certbot instruction generator. There was a content migration to a new website system recently and it might be related to that.
There is no such snap as certbot-nginx.
The correct instructions can be found on an archived version here: Certbot - Ubuntufocal Nginx
We'll try to get this fixed soon.
There is also no such snap as certbot-apache and snap install certbot --classic gives a version of certbot without apache plugin.
Facebook welcomes you to the club of "nuking yourself off the net" :grinning_face_with_smiling_eyes:
Hi @codesalatdev and welcome to the LE community forum :slight_smile:
Even if "latest certbot snap release now doesn't include an --apache plugin" is true (haven't checked; don't rely on Apache much), one can always use certbot with --webroot [with any web service].
So, I don't see how that nukes anybody to anywhere.
Unless... you are implying that Apache users aren't capable of handling the issued certificate by hand?
If users go to your install how-to page, select both OS and Webserver and the instructions just don't work because there is no installation candidate, I would call that issue pretty substantial. So while "nuking" was merely a joke (taken a little bit too seriously), relying on users to find an alternative way to install certbot despite the official docs saying otherwise is IMHO a pretty low standard to go by in the first place.
This has nothing to do with Apache users, since installing certbot is the issue, not handling it as you imply.
Thank you. I read that. I wrote my comment to add the information that certbot-apache was also missing. I didn't intent to start a convo about handling certificates by hand.
Ok, we can all agree the instruction site is definitely broken.
I now see:
sudo snap install certbot-apache
then
sudo certbot --apache
Which is a clear contradiction: Install "C-A" then run "C" with -A.
[there is no "C-A" and "C" was never installed]
The Certbot snap comes with both the Apache and nginx plugins built-in.
If you don't see the Apache plugin after installing the Certbot snap, it most likely means that you have a second copy of Certbot installed and it is taking priority in your PATH.
