My domain is: mcwin.ddns.net
Domain: mcwin.ddns.net
Type: connection
Detail: Fetching http://mcwin.ddns.net/.well-known/acme-challenge/0W0ikVfWp5AVgBL8m8YRTG8P3OxIVmtSkxuXhQp782A: Timeout during connect (likely firewall problem)
My web server is (include version): Apache 2.4.53
The operating system my web server runs on is (include version): Debian 11.3.0 (installed using non-free)
or certbot-auto --version
if you're using Certbot): 1.26.0
Different things I've done to test try and get this to work:
- disable my vpn on my Asus AX88U router with Merlin
- disable the firewall on the server
- corrected my port forwarding for http and https
- inbound firewall under network settings on the vpn client section on the router to "Allow"
- installing the SSL cert from right within the router settings on the DDNS section of asus merlin v386.5.2 (never went through, continued to say "Authorizing")
After each attempt from the different things I've tried, I received an error message from LetsDebug.net as seen in Error1.png
I disabled the router firewall completely and received the error message as seen in Error2.png
I made sure that I used the public IP of my server when creating the A record using no-ip. Each time the public IP changed as a result of me turning off the vpn I updated the A record.
