Error in connection establishment: certificate transparency required
I’m getting an error similar to Certificate transparency error on Chrome 74 after extending certificate
I have an app on app.speakrandom.com that uses a WebSocket API at api1.speakrandom.com
This API uses let’s encrypt to use https. On Windows in Chrome, I get the following error (from the console in app.speakrandom.com:
WebSocket connection to 'wss://api1.speakrandom.com/socket.io/?EIO=3&transport=websocket' failed: Error in connection establishment: net::ERR_CERTIFICATE_TRANSPARENCY_REQUIRED
This happened after renewing the certificate. Before this it was working perfectly.
Please help me out here, thanks.
My domain is: api1.speakrandom.com
I ran this command: sudo certbot renew --nginx
http-01 challenge for api1.speakrandom.com
Waiting for verification…
new certificate deployed with reload of nginx server; fullchain is
/etc/letsencrypt/live/api1.speakrandom.com/fullchain.pem
  • Your account credentials have been saved in your Certbot
My web server is (include version): nginx version: nginx/1.14.2
The operating system my web server runs on is (include version): Debian 10
My hosting provider, if applicable, is: Google Cloud Compute Engine
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Could you please read over my post at $50 bounty request: a Chrome log export of the "certificate transparency required" error?
I would really appreciate it if we could help each other out!
Hmm this is awkward… I went ahead and followed your instructions. The log was well written, but then I remembered that I forgot to add the --bwsi flag, so I went ahead and started logging again to the same file (overwritten), but this time the error wasn’t produced anymore.
Sorry about that, what can I do now?
Ahhhhhh! If it was overwritten, that’s too bad. Thank you for trying anyway.
At least it wasn’t a $1,000,000 Bitcoin wallet or something. :slight_smile:
(I hope someone succeeds in claiming the bounty soon and we get some more visibility into why this error happens!)
