Error: During secondary validation: Remote PerformValidation RPC failed
I ran this command: certbot renew --dry-run
Domain:
Type: serverInternal
Detail: During secondary validation: Remote PerformValidation RPC failed
Failed to renew certificate with error: Some challenges have failed.
All simulated renewals failed.
That is an unusual error. Do you limit access to your server by country or geography? Because Let's Encrypt recently started using more points around the world to validate from. Seeing "Seconday validation" in the error message means this might be happening to you.
People who previously only allowed USA (and their home countries) would no longer work.
That's an internal error with Let's Encrypt's servers. Are you consistently getting it, or does it work if you try again?
I am getting the same error
Another report here:
I'm guessing that staging is down.
I'm getting same RPC failed error from my own test server using --dry-run
We've identified a change we made (to our own certs, doh!) has broken the secondary validation.
We're going to roll that back now.
This will break certbot --dry-run and certbot --staging (or other uses of staging) commands only -- you should be able to renew still otherwise
For the staging environment only, correct?
Yes, staging only
It's fixed
It's working now... Thx
