Certbor Renew fails: Remote PerformValidation RPCs failed
My domain is: drone.lho.io
I ran this command: certbot renew --dry-run
Processing /etc/letsencrypt/renewal/drone.lho.io.conf
Plugins selected: Authenticator webroot, Installer nginx
http-01 challenge for drone.lho.io
Attempting to renew cert (drone.lho.io) from /etc/letsencrypt/renewal/drone.lho.io.conf produced an unexpected error: Failed authorization procedure. drone.lho.io (http-01): urn:ietf:params:acme:error:serverInternal :: The server experienced an internal error :: Remote PerformValidation RPCs failed. Skipping.
My web server is (include version): nginx/1.10.3
The operating system my web server runs on is: Debian 9.7, Linux 4.9.0-8-amd64
My hosting provider, if applicable, is: hetzner.de
I can login to a root shell on my machine: Yes
I’m using a control panel to manage my site: No
The version of my client is: certbot 0.28.0
More information:
My bare nginx config looks like this:
# HTTPS Server
    listen 80;
    listen [::]:80;
    server_name drone.lho.io;
    error_log /var/log/nginx/drone_error.log;
    # lets encrypt redirect
    location /.well-known {
            alias /var/www/letsencrypt/.well-known;
        proxy_pass http://127.0.0.1:8082/;
        proxy_http_version 1.1;
        proxy_set_header Connection "upgrade";
        proxy_set_header Host $http_host;
        proxy_set_header X-Forwarded-Proto https;
        proxy_set_header X-Nginx-Proxy true;
        proxy_redirect off;
    # lets encrypt will add settings here for ssl!
After installing the certificate, cerbot added some stuff:
# HTTPS Server
    listen 80;
    listen [::]:80;
        proxy_redirect off;
    ssl_certificate /etc/letsencrypt/live/drone.lho.io/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/drone.lho.io/privkey.pem; # managed by Certbot
ssl_session_cache shared:le_nginx_SSL:1m; # managed by Certbot
ssl_session_timeout 1440m; # managed by Certbot
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # managed by Certbot
ssl_prefer_server_ciphers on; # managed by Certbot
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256 ECDHE-ECDSA-AES256-GCM-SHA384 ECDHE-ECDSA-AES128-SHA ECDHE-ECDSA-AES256-SHA ECDHE-ECDSA-AES128-SHA256 ECDHE-ECDSA-AES256-SHA384 ECDHE-RSA-AES128-GCM-SHA256 ECDHE-RSA-AES256-GCM-SHA384 ECDHE-RSA-AES128-SHA ECDHE-RSA-AES128-SHA256 ECDHE-RSA-AES256-SHA384 DHE-RSA-AES128-GCM-SHA256 DHE-RSA-AES256-GCM-SHA384 DHE-RSA-AES128-SHA DHE-RSA-AES256-SHA DHE-RSA-AES128-SHA256 DHE-RSA-AES256-SHA256 EDH-RSA-DES-CBC3-SHA"; # managed by Certbot
    if ($scheme != "https") {
    } # managed by Certbot
This used to work fine. However, I reset the config file and reinstalled the certificate using certbot --authenticator webroot -w /var/www/letsencrypt/ --installer nginx. The configuration file this time looked a little different:
# HTTPS Server
        proxy_redirect off;
    if ($host = drone.lho.io) {
    listen 80;
    listen [::]:80;
Renewal failed with the same log output described above. However, if I don’t force HTTPS redirects, the renewal works. The config file is as follows:
# HTTPS Server
    listen 80;
    listen [::]:80;
        proxy_redirect off;
Edit: For clarification: Reinstallation of certificate works, just as well as removing the certificate and installing a completely new one does (you’ll notice the certificate was issued today because I also tried removing everything and installing a new certificate).
The config file for renewal looks like this:
version = 0.28.0
archive_dir = /etc/letsencrypt/archive/drone.lho.io
cert = /etc/letsencrypt/live/drone.lho.io/cert.pem
privkey = /etc/letsencrypt/live/drone.lho.io/privkey.pem
chain = /etc/letsencrypt/live/drone.lho.io/chain.pem
fullchain = /etc/letsencrypt/live/drone.lho.io/fullchain.pem
[renewalparams]
authenticator = webroot
installer = nginx
account = XXX
webroot_path = /var/www/letsencrypt,
[[webroot_map]]
drone.lho.io = /var/www/letsencrypt
This error technically should not happen, but it usually coincides with network or request timeout conditions.
The first thing I'd try is to fix/drop your IPv6/AAAA record - Let's Debug . Again, Let's Encrypt should in theory not be fatally affected by it, but it's probably good to fix it up for regular visitors.
The other thing I would suggest is trying to use the nginx authenticator - you may as well, since you are using the nginx installer anyway. The reason this may help is that Certbot will inject the challenge response directly into your port 80 virtualhost, which will bypass any complications relating to your reverse proxying, webroot or your HTTPS redirect.
certbot renew --cert-name drone.lho.io \
-a nginx -i nginx --dry-run
Wow, thanks! I fixed the IPv6 records and it actually resolved the problem. My copy/paste had just missed a number when I set up a new server.
However, changing to the nginx authenticator also worked fine. Thank you very much :slight_smile:
