My domain is: izlem.duranonline.net
I ran this command: sudo certbot certonly --dry-run -d izlem.duranonline.net
1: Nginx Web Server plugin (nginx)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press 'c' to cancel): 1
Plugins selected: Authenticator nginx, Installer None
Simulating renewal of an existing certificate for izlem.duranonline.net
http-01 challenge for izlem.duranonline.net
Using default addresses 80 and [::]:80 ipv6only=on for authentication.
Challenge failed for domain izlem.duranonline.net
Domain: izlem.duranonline.net
Type: serverInternal
Detail: During secondary validation: Remote PerformValidation RPC
failedUnfortunately, an error on the ACME server prevented you from
completing authorization. Please try again later.
My web server is (include version): nginx 1.18.0
The operating system my web server runs on is (include version): debian 11 bullseye
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.12.0
