During secondary validation: Remote PerformValidation RPC failed
My domain is: apps.rak*******.com
I ran this command: sudo certbot certonly --dry-run --nginx -d apps.rakcerambd.com
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
Simulating a certificate request for apps.rak*******.com
http-01 challenge for apps.rak*******.com
Using default addresses 80 and [::]:80 ipv6only=on for authentication.
Challenge failed for domain apps.rak*******.com
    Domain: apps.rak*******.com
    Type: serverInternal
    Detail: During secondary validation: Remote PerformValidation RPC
    failed
    Unfortunately, an error on the ACME server prevented you from
    completing authorization. Please try again later.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.11.0
nginx version: nginx/1.20.1
In case you have not yet seen, Let's Encrypt has identified a problem in their staging system. They are actively working to correct it.
And, it may already be corrected :slight_smile:
Fixed.
