Error: DNS problem: query timed out looking up A for www.osprey.mx
We are having issues obtaining a cert and I’ve repeatedly encountered the error: Failed authorization procedure. www.osprey.mx (http-01): urn:acme:error:dns :: DNS problem: query timed out looking up A for www.osprey.mx
We have previously been able to issue a cert, but now we’re unable to.
My domain is: www.osprey.mx
I ran this command: certbot --email <MY_EMAIL> --domain www.osprey.mx --non-interactive --config-dir <MY_CONFIG_DIR> --agree-tos --manual --preferred-challenges http --manual-public-ip-logging-ok --manual-auth-hook challengeHook.sh --rsa-key-size 4096 certonly
http-01 challenge for www.osprey.mx
My web server is (include version): n/a
The operating system my web server runs on is (include version): n/a
My hosting provider, if applicable, is: n/a
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.14.0
I don’t know if this is why Let’s Encrypt is failing, but FWIW, your authoritative DNS service has a misconfiguration:
https://dnsviz.net/d/servicios-nic.com.mx/dnssec/
$ dig +norecurse @o.mx-ns.mx servicios-nic.com.mx
; <<>> DiG 9.15.7-Ubuntu <<>> +norecurse @o.mx-ns.mx servicios-nic.com.mx
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 4170
;; flags: qr; QUERY: 1, ANSWER: 0, AUTHORITY: 3, ADDITIONAL: 7
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;servicios-nic.com.mx.          IN      A
;; AUTHORITY SECTION:
servicios-nic.com.mx.   86400   IN      NS      dns1.servicios-nic.com.mx.
servicios-nic.com.mx.   86400   IN      NS      dns2.servicios-nic.com.mx.
servicios-nic.com.mx.   86400   IN      NS      dns3.servicios-nic.com.mx.
;; ADDITIONAL SECTION:
dns1.servicios-nic.com.mx. 86400 IN     A       200.94.181.1
dns2.servicios-nic.com.mx. 86400 IN     A       200.94.181.2
dns3.servicios-nic.com.mx. 86400 IN     A       200.94.181.3
dns1.servicios-nic.com.mx. 86400 IN     AAAA    2001:1250::1811
dns2.servicios-nic.com.mx. 86400 IN     AAAA    2001:1250::1812
dns3.servicios-nic.com.mx. 86400 IN     AAAA    2001:1250::1813
;; Query time: 39 msec
;; SERVER: 200.23.1.1#53(200.23.1.1)
;; WHEN: Thu Jan 09 19:52:38 UTC 2020
;; MSG SIZE  rcvd: 238
The three nameservers have IPv6 glue records, though not authoritative records, and none of the IPs work.
That might be delaying resolution.
Thanks for the response, that was really helpful.
How to solve this issue?, I have the same problem but i dont have a lot of experience with DNS
