Error: Could not issue a Let's Encrypt SSL/TLS certificate
My domain is: amaformacion.org
Error en subdominio: aulavirtual.amaformacion.org
I ran this command:Intalar Let's Encrypt SSL/TLS Certificate
It produced this output: Error: Could not issue a Let's Encrypt SSL/TLS certificate for aulavirtual.amaformacion.org . Authorization for the domain failed.
My web server is (include version): 7.1.33
The operating system my web server runs on is (include version): -
My hosting provider, if applicable, is: Gigas
I can login to a root shell on my machine (yes or no, or I don't know): No se
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk Onyx 17.8.11
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): -
Mensaje de error:
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/219185156977.
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: DNS problem: NXDOMAIN looking up A for aulavirtual.amaformacion.org - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for aulavirtual.amaformacion.org - check that a DNS record exists for this domain
The subdomain aulavirtual does not exist (yet) in the zone for amaformacion.org.
Si existe porque está creado.. te envío imagen.
No existe.
Both authoritative nameservers agree that it doesn't exist:
nslookup aulavirtual.amaformacion.org d0.org.afilias-nst.org
Served by:
- ns53.domaincontrol.com
          amaformacion.org
- ns54.domaincontrol.com
          amaformacion.org
nslookup aulavirtual.amaformacion.org ns53.domaincontrol.com
*** UnKnown can't find aulavirtual.amaformacion.org: Non-existent domain
nslookup aulavirtual.amaformacion.org ns54.domaincontrol.com
Primero, debe poner el nombre en su DNS, luego existirá.
Muchas gracias a todos, ya está solucionado.
Un saludo.
