Error: Could not issue a Let's Encrypt SSL/TLS certificate for (domain)
My domain is: urbandish.ca
I ran this command: plesk, install Let’s Encrypt Cert.
Error: Could not issue a Let’s Encrypt SSL/TLS certificate for urbandish.ca .
Details
Could not obtain directory: Invalid response.
Details:
Type: about:blank
Status: 503
Detail: {
“type”: “urn:acme:error:serverInternal”,
“detail”: “The service is down for maintenance or had an internal error. Check https://letsencrypt.status.io/ for more details.”
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk
Nevermind, I see that there is a system wide issue.
Hi @pjmckeown,
I believe we are very close to resolving the statuspage incident. Can you retry your issuance request? I believe it will now succeed.
Thanks for the quick response, yes, it worked now. Thanks!!
