Certificate remains expired after re-issuance
Each time I try to re-issue the certificate, it comes back as invalid, expired in August. Is there still an issue?
Hi @gardfish,
I split this reply off of the previous post because it is unrelated to the incident mentioned in the previous thread.
Can you provide answers to the default “Help” template? It will help the community figure out the root cause of your problem.
Thanks for splitting the post. Here are the details:
oame.on.ca
sudo ./certbot-auto
Congratulations! You have successfully enabled https://www.oame.on.ca and
https://oame.on.ca
https://www.ssllabs.com/ssltest/analyze.html?d=www.oame.on.ca
https://www.ssllabs.com/ssltest/analyze.html?d=oame.on.ca
    /etc/letsencrypt/live/www.oame.on.ca/fullchain.pem
    /etc/letsencrypt/live/www.oame.on.ca/privkey.pem
    Your cert will expire on 2019-02-28. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot-auto
    again with the “certonly” option. To non-interactively renew all
    of your certificates, run “certbot-auto renew”
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
Server version: Apache/2.4.34 (Amazon)
Amazon Linux AMI release 2018.03
AWS
Yes
No control panel
Thanks!
oame.on.ca
sudo certbot-auto
https://oame.on.ca
AWS
Yes
No control panel.
Thanks!
Hi @gardfish
your configuration ( https://check-your-website.server-daten.de/?q=oame.on.ca ):
• http://oame.on.ca/ 301 https://oame.on.ca/ 0.504 A
• http://www.oame.on.ca/ 301 https://www.oame.on.ca/ 0.343 A
• https://oame.on.ca/ 200 2.176 N
Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
• https://www.oame.on.ca/ 200 2.450 B
Your www-version is ok
oame.on.ca 443 Certificate/chain invalide and wrong name Tls12 ECDH Ephermal 256 Aes256 256 Sha384 not supported ok
www.oame.on.ca 443 ok Tls12 DiffieHellman 2048 Aes128 128 Sha256 not supported ok
But your non-www - version uses a self signed certificate, which is expired.
So you should create one certificate with two domain names - www + non-www.
sudo certbot-auto renew -d oame.on.ca -d www.oame.on.ca
If that doesn't work, share your configuration file. Or share your file
/var/log/letsencrypt/letsencrypt.log
there are the details of your configuration.
PS: You have already such a certificate, created today.
X509v3 Subject Alternative Name:
DNS:oame.on.ca
DNS:www.oame.on.ca
So don't create a new certificate, instead check your configuration. So the non-www version use this certificate.
Thanks JuergenAuer,
In theory they should both be using the same certificate as www.oame.on.ca is just an alias for oame.on.ca
<VirtualHost *:443>
ServerAdmin aws@oame.on.ca
DocumentRoot /var/www/html
ServerName oame.on.ca
ServerAlias www.oame.on.ca
ErrorLog logs/error_log
CustomLog logs/access_log common
RewriteEngine on
// Some rewrite rules in this file were disabled on your HTTPS site,
// because they have the potential to create redirection loops.
// RewriteCond %{SERVER_NAME} =www.oame.on.ca [OR]
// RewriteCond %{SERVER_NAME} =oame.on.ca
// RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
SSLCertificateFile /etc/letsencrypt/live/www.oame.on.ca/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/www.oame.on.ca/privkey.pem
</VirtualHost>
Would you recommend that I split them out into separate VirtualHosts?
Now my online tool has the correct certificate (www-version) with two domain names.
CN=www.oame.on.ca
30.11.2018
28.02.2019
oame.on.ca, www.oame.on.ca - 2 entries
But the non-www version uses the self signed.
Self signed certificates are often found in the standard configuration file. Are there other configuration files with VirtualHost - elements?
Normally such a configuration should work. But you can try it. Two separate files with two separate VirtualHosts, but with the same certificate.
I appreciate your time on this JuergenAuer. You were exactly right. I found the default ssl.conf configuration in the conf.d folder and was able to identify the VirtualHost that was causing the issue.
Thank you so much!
Happy to read that. Now it looks good:
• http://oame.on.ca/ 301 https://oame.on.ca/ 0.233 A
• http://www.oame.on.ca/ 301 https://www.oame.on.ca/ 0.223 A
• https://oame.on.ca/ 200 2.227 B
• https://www.oame.on.ca/ 200 2.243 B
And both connections are using the same certificate with two domain names.
