- 12t9edda.site
$ certbot --webroot -w /var/www/letsencrypt -d www.12t9edda.site -d 12t9edda.site --installer nginx
Certificate is saved at: /etc/letsencrypt/live/www.12t9edda.site/fullchain.pem
Key is saved at: /etc/letsencrypt/live/www.12t9edda.site/privkey.pem
This certificate expires on 2021-11-14.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Successfully deployed certificate for www.12t9edda.site to /etc/nginx/conf.d/12t9edda.site.conf
Successfully deployed certificate for 12t9edda.site to /etc/nginx/conf.d/12t9edda.site.conf
Your existing certificate has been successfully renewed, and the new certificate has been installed.
* Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
* Donating to EFF: https://eff.org/donate-le
- nginx version: nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version) :
- ubuntu 20.04
My hosting provider, if applicable, is :
- DigitalOcean
I can login to a root shell on my machine (yes or no, or I don't know) :
- YES
I'm using a control panel to manage my site (no, or provide the name and version of the control panel) :
- NO CONTROL PANEL
or certbot-auto --version
if you're using Certbot) :
- certbot 1.18.0
PROBLEM :
I have a digitalocean droplet with Nginx installed this webserver serves some content for different websites, some for subdomains (somthing.example.com) others for mapped root domains (foo.com, bar.com...).
SSLs are generated with cerboot for root domains, and for subdomains I have obtained a wild-card certificate that points to "*.example.com", everything was fine until I had to point this domain "12t9eda.site" with the command provided above (this domain is the only one that starts with numbers ) when I create SSL certificate for this domain (12t9edda.site) other subdomains (*.example.com) got affected and lost their certificate (browsers show a message that this subdomain is not secure and the certificate was issued to 12t9edda.site) if I remove the SSL certificate for "12t9edda.site" everything works as expected.
i been struggling with this problem for about 2 weeks now and I found no clue on the internet or just how to debug certificates with Nginx and certbot.
hope this was clear, thanks to anyone that can provide some help
thanks in advance
