So I had my certificate working fine, but now I’m trying to change it to a subdomain. It already had an nginx config file and a working directory and a server that runs node. I didn’t need to generate a new config file for nginx but I think it did.
I ran the command: sudo certbot -d sub.domain.com --nginx --webroot-path “/home/site/htdocs”
And now instead of showing the site, it’s showing a different “welcome to nginx” page. I don’t know if I have the webroot correct, because I didn’t set it up the first time and it didn’t show it anywhere.
This is on Ubuntu 16.4, via digital ocean. Certbot is 0.28.0
Here is the output from the command:
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/sub.domain.com.conf)
What would you like to do?
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/default
nginx: [error] invalid PID number "" in "/run/nginx.pid"
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Traffic on port 80 already redirecting to ssl in /etc/nginx/sites-enabled/default
Congratulations! You have successfully enabled https://sub.domain.com
https://www.ssllabs.com/ssltest/analyze.html?d=sub.domain.com
/etc/letsencrypt/live/sub.domain.com/fullchain.pem
/etc/letsencrypt/live/sub.domain.com/privkey.pem
Your cert will expire on 2019-05-11. To obtain a new or tweaked
with the "certonly" option. To non-interactively renew *all* of
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
Show certbot certificates
So you can better understand what certs you have and which domains they cover.
Certbot will create an SSL version of an http vhost config and add the required code to enable SSL.
Check ls -l /etc/nginx/sites-enabled/
to see which vhost config are in use.
Before I reran the command I did not have that folder, and it was still working. I’d like to direct it to use the same path it used before. I still don’t understand where the Welcome to Nginx page is coming from.
I still have a copy of the old version, if I make a new copy, is there a way I can safely get a certificate for the new domain without changing the path?
I still can’t find anywhere that references the actual path to my files. If I start over with my working configuration, is there a way for me to get a new cert for my my new subdomain without changing anything with nginx? I just want it to work the same as it did before.
we need informations. Please answer the following questions (standard template from #help ):
beta.lospec.com has two ip addresses, one ipv4, one ipv6: Both use the correct certificate
CN=beta.lospec.com
10.02.2019
11.05.2019
expires in 84 days beta.lospec.com - 1 entry
There is a www.beta.lospec.com as A-record defined, there the config is wrong. But if you don't want to use that www - domain, this isn't relevant, you can ignore it. Or remove the DNS A record.
Yeah it has the right certificate now, but when I gave it the new certificate it stopped pointing to my actual web server so it doesn’t return my website
I copied the file default from sites available and made beta.lospec.com.conf and changed the domain in it, then made a link in site-enabled
Now I’m getting 502 Bad Gateway - nginx/1.10.3 (Ubuntu)
I also tried starting over, and doing certbot -d “beta.lospec.com” -certonly, then edited the config file to include the subdomain, and I seem to be having the same problem, 502 bad gateway.
root@afterimagehostupdate-s-3vcpu-1gb-nyc3-01:~# sudo certbot -d betatest.lospec.com --installer nginx --webroot -w '/home/lospec/htdocs'
Plugins selected: Authenticator webroot, Installer nginx
http-01 challenge for betatest.lospec.com
Using the webroot path /home/lospec/htdocs for all unmatched domains.
Failed authorization procedure. betatest.lospec.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://betatest.lospec.com/.well-known/acme-challenge/G05zSRbAXPXUK_DF5wdD8IQ5pN5fm3sTHge8TbE5Pac: "<html>\r\n<head><title>404 Not Found</title></head>\r\n<body bgcolor=\"white\">\r\n<center><h1>404 Not Found</h1></center>\r\n<hr><center>"
Domain: betatest.lospec.com
Detail: Invalid response from
