Issue with renewing certificate
My domain is: alkarkhi.com
Failed to renew certificate alkarkhi.com with error: The manual plugin is not working; there may be problems with your existing configuration. The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.')
My web server is (include version): nginx v1.14.2
The operating system my web server runs on is (include version): Debian v10.10
My hosting provider, if applicable, is: evolution-host.com
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.17.0
I also switched from Apache to Nginx and I created the certificates when I used Apache. Maybe that's the problem?
Probably not. Have you been able to renew the cert before using certbot renew? Because the error message suggests you initially issued the cert using --manual. If you did that, you can't renew automatically, and if you think about it for a minute, the reason is obvious--when you use --manual, cert issuance requires manual intervention. If you're running non-interactively (as renew does), there's no way to provide that manual intervention.
@danb35 Yes I think I used --manual. How would I change it to automatic
I see:
Addresses: 2001:41d0:800:2e90:6d72:2ffb:8267:1
           51.195.152.242
With different replies:
curl -Iki6 alkarkhi.com
HTTP/1.1 403 Forbidden
Connection: close
Content-Type: text/html
Cache-Control: no-cache
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
Content-Security-Policy: frame-ancestors 'self'
Content-Length: 3444
curl -Iki4 alkarkhi.com
Server: nginx
Date: Sat, 10 Jul 2021 16:58:15 GMT
Content-Length: 178
Thanks for the heads up. My ISP doesn't give out ipv6 addresses for some reason so its hard to check if its working right. Can you check again?
Hello :slightly_smiling_face:
Being sure to heed what @rg305 has wisely pointed out, you might be able to use the following:
sudo certbot --cert-name alkarkhi.com --nginx -d "alkarkhi.com,www.alkarkhi.com"
@griffin Hello. Whats the difference to:
sudo certbot --cert-name alkarkhi.com --nginx -d "alkarkhi.com,*.alkarkhi.com
It uses the nginx authenticator, which automatically satisfies http-01 challenges, instead of the manual authenticator, which does not.
No change.
I see a huge change, @rg305.
"*" and "www" are handled very differently.
Certs that contain wildcards must be handled by DNS authentication (ONLY).
@rg305
I think @certb0t's nginx configuration has special handling for .well-known. If you look in the first Let's Debug blue box, you'll see what I mean.
@rg305
If you curl http://alkarkhi.com/.well-known/acme-challenge/test, do you get differing responses?
@rg305 So I'll have to manually add new subdomains then if I want automatic?
I see the forwarding, but if the rest of the site is not serving the same content, then I can only assume they are either not on the same system or won't provide the same content once secure.
Recall that step one is having a fully functional web site.
This seems to fail that as is.
DNS authentication can be automated - if the DSP is known to work with the ACME client being used.
I'm only seeing a SERVFAIL for the A record right now, which is odd since both the A and AAAA records are returned. :thinking:
Does that depend on the CA?
Clean now.
No but that doesn't negate the lack of synchronization of the rest of the site.
So that even if we "WIN". we will soon see another TOPIC with "Sometimes my site works and sometimes it doesn't after install LE cert."
[When it did that even before the cert was obtained]
