Certificate renewal Issue
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=pirelclothing.com), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is:pirelclothing.com
I ran this command: sudo certbot renew
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',)
Attempting to renew cert (pirelclothing.com) from /etc/letsencrypt/renewal/pirelclothing.com.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',). Skipping.
/etc/letsencrypt/live/pirelclothing.com/fullchain.pem (failure)
My web server is (include version): Nginx
The operating system my web server runs on is (include version): Ubuntu 18.4
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.27.0
I tried redoing the process but get the same error.
I am not able to remove the existing cert to redo it fresh.
I am new to this and any help would be much appreciated.
Thanks
Welcome to the Let's Encrypt Community :slightly_smiling_face:
You cannot use renew with manual authentication without specifying a script with --manual-auth-hook.
Based on your certificate history, it looks like you already have a certificate that won't expire until February 10 that was acquired through some flavor of cPanel, which likely supports AutoSSL and will automatically renew the certificate at the appropriate time. However, that certificate is not currently installed and thus not being served. Currently, an apex (pirelclothing.com) and wildcard (*.pirelclothing.com) certificate (A&W certificate) is currently installed and being served. I'm assuming it is that certificate you are trying to renew with certbot. You can do this, but I would highly recommend just installing the first certificate I mentioned (non-wildcard) and letting cPanel automatically renew it for you.
If you wish to proceed with manually acquiring/renewing the wildcard certificate, use:
sudo certbot certonly --cert-name pirelclothing.com --manual --preferred-challenges dns -d "pirelclothing.com,*.pirelclothing.com" --deploy-hook "sudo nginx -s reload" --keep
Hey,
Thanks for your solution. It worked just fine.
is there a way to make the renewal automatic or do i have to manually do it every 90 days?
Appreciate your help.
To elaborate on other certificate history,
i have pointed just the main apex(pirelclothing.com) to AWS. Rest all is in my cpanel server to handle my mail exchange. Hence that cpanel certificate.
Thanks
:partying_face:
Glad all went well!
You probably don't want to cover "the rest" with your own certificate. Without installing your own certificate, you are probably redirected to a hosting instance of your cPanel provider that is already covered by their certificate. See webdisk.pirelclothing.com as an example.
You missed a couple:
cpanel.pirelclothing.com. 14399 IN CNAME pirelclothing.com.
webmail.pirelclothing.com. 14399 IN CNAME pirelclothing.com.
I'm assuming that you acquired and installed the wildcard certificate on your AWS instance. If you're only (supposed to be) serving the apex and www there, you don't need a wildcard certificate and could just use:
sudo certbot run --cert-name pirelclothing.com --nginx -d "pirelclothing.com,www.pirelclothing.com" --keep
That will also install the certificate for you and update your nginx configuration (which may cause duplication problems that should be easy to fix by removing your own redirects and ssl vHost). You want certbot to manage those things for you rather than doing them yourself. This will also fix your missing 301 redirect from http://pirelclothing.com to https://pirelclothing.com.
Once that succeeds, you can test your automatic renewals using:
sudo certbot renew --dry-run
http://pirelclothing.com currently...
Tried this,
got this error
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA. You may need to use an authenticator plugin that can do challenges over DNS.
Sorry to bother you but could you help with this authenticator Plugin?
Really appreciate for all your help.
Many Thanks
Did you run the command exactly as I posted it? The nginx authenticator (--nginx) cannot obtain wildcard (*.) certificates. If possible, please post a complete dump of the command and it's output so that we cab analyze further. I want to determine if there might be a bug in certbot. Your certbot version is quite ancient, so it may be a known issue and you might just need to update your certbot.
Attached the screenshot for the whole setup
I believe this is a known issue with your version of certbot. Please use the link I provided above to the official certbot website and follow the procedure there to install the snap version of certbot then try the command I gave you again.
Thank you.
That worked just perfect.
Thanks for your time and help.
Edit:
I am not able to login into my wordpress installation now. It gives me a 404 Error
and the apex domain goes to the nginx page.
Any idea where i went wrong?
Thanks
I did some checking...
You got a new certificate covering only pirelclothing.com and www.pirelclothing.com. :partying_face:
Your redirects look great now too. :partying_face:
http://www.pirelclothing.com
301 Moved Permanently
https://www.pirelclothing.com/
https://pirelclothing.com/
200 OK
200 OK
I see that you've centered on the apex domain name (pirelclothing.com) rather than the www subdomain (www.pirelclothing.com) as your canonical domain name, which is a wise decision in my opinion.
I previously pointed out that http://pirelclothing.com was serving content from the default nginx instance. Your WordPress installation is still there. You're just not serving it because https://pirelclothing.com.
What says sudo nginx -T ?
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        tcp_nodelay on;
        keepalive_timeout 65;
        types_hash_max_size 2048;
        # server_tokens off;
        # SSL Settings
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
        ssl_prefer_server_ciphers on;
        # Logging Settings
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # Virtual Host Configs
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
        listen 80 default_server;
        # SSL configuration
        root /var/www/html;
        server_name _;
                try_files $uri $uri/ =404;
        #location ~ \.php$ {
        #       include snippets/fastcgi-php.conf;
        #       # With php-fpm (or other unix sockets):
        #       fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
        #       # With php-cgi (or other tcp sockets):
        #       fastcgi_pass 127.0.0.1:9000;
        # concurs with nginx's one
        #location ~ /\.ht {
        #       deny all;
#server {
#       listen 80;
#       listen [::]:80;
#       server_name example.com;
#       root /var/www/example.com;
#       index index.html;
#       location / {
#               try_files $uri $uri/ =404;
        # SSL configuration
        root /var/www/html;
    server_name pirelclothing.com; # managed by Certbot
        #location ~ /\.ht {
        #       deny all;
    ssl_certificate /etc/letsencrypt/live/pirelclothing.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/pirelclothing.com/privkey.pem; # managed by Certbot
    if ($host = pirelclothing.com) {
    } # managed by Certbot
        listen 80 ;
        listen [::]:80 ;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
# configuration file /etc/nginx/sites-enabled/wordpress:
    if ($host = www.pirelclothing.com) {
     listen 80;
     listen [::]:80;
     server_name *.pirelclothing.com;
    listen 443 ssl http2;
    listen [::]:443 ssl http2;
    root /var/www/wordpress;
    index  index.php;
   if ($host != "pirelclothing.com") {
      return 301 https://pirelclothing.com$request_uri;
    ssl_trusted_certificate /etc/letsencrypt/live/pirelclothing.com/chain.pem;
    ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
    ssl_ciphers 'TLS13+
    ssl_session_cache shared:SSL:50m;
    ssl_session_timeout 1d;
    ssl_ecdh_curve X25519:sect571r1:secp521r1:secp384r1;
    client_max_body_size 100M;
    autoindex off;
        try_files $uri $uri/ /index.php?$args;
    location ~ \.php$ {
         fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
         fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
         include fastcgi_params;
# configuration file /etc/nginx/snippets/fastcgi-php.conf:
# regex to split $uri to $fastcgi_script_name and $fastcgi_path
fastcgi_split_path_info ^(.+\.php)(/.+)$;
# Check that the PHP script exists before passing it
try_files $fastcgi_script_name =404;
# Bypass the fact that try_files resets $fastcgi_path_info
# see: http://trac.nginx.org/nginx/ticket/321
set $path_info $fastcgi_path_info;
fastcgi_param PATH_INFO $path_info;
fastcgi_index index.php;
include fastcgi.conf;
# configuration file /etc/nginx/fastcgi.conf:
fastcgi_param  QUERY_STRING       $query_string;
fastcgi_param  REQUEST_METHOD     $request_method;
fastcgi_param  CONTENT_TYPE       $content_type;
fastcgi_param  CONTENT_LENGTH     $content_length;
fastcgi_param  SCRIPT_NAME        $fastcgi_script_name;
fastcgi_param  REQUEST_URI        $request_uri;
fastcgi_param  DOCUMENT_URI       $document_uri;
fastcgi_param  DOCUMENT_ROOT      $document_root;
fastcgi_param  SERVER_PROTOCOL    $server_protocol;
fastcgi_param  REQUEST_SCHEME     $scheme;
fastcgi_param  HTTPS              $https if_not_empty;
fastcgi_param  GATEWAY_INTERFACE  CGI/1.1;
fastcgi_param  SERVER_SOFTWARE    nginx/$nginx_version;
fastcgi_param  REMOTE_ADDR        $remote_addr;
fastcgi_param  REMOTE_PORT        $remote_port;
fastcgi_param  SERVER_ADDR        $server_addr;
fastcgi_param  SERVER_PORT        $server_port;
fastcgi_param  SERVER_NAME        $server_name;
# PHP only, required if PHP was built with --enable-force-cgi-redirect
fastcgi_param  REDIRECT_STATUS    200;
# configuration file /etc/nginx/fastcgi_params:
