Issue with renewing certificate
Nginx misconfiguration then?
sudo nginx -T
OR
they are two different systems.
I'm actually confused haha. Do you guys want the nginx config?
Yeah. That would help. Putting a test file maybe moreso.
curl -Iki4 alkarkhi.com
Server: nginx
Date: Sat, 10 Jul 2021 16:58:15 GMT
Content-Type: text/html
Content-Length: 178
curl -Iki6 alkarkhi.com
HTTP/1.1 403 Forbidden
Connection: close
Cache-Control: no-cache
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
Content-Security-Policy: frame-ancestors 'self'
Content-Length: 3444
Those two should be the exact same thing.
That's very true. I see what you mean, @rg305. We need to determine if it's the same system.
@certb0t
Can you create a file named test in your webroot directory containing 1234.
If @rg305 can curl the test file on both systems (and hopefully get a 200 back), we will have a match. If not, could be configuration or two different systems.
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
    listen 80 default_server;
    server_name it-does-not-matter;
    listen 443 ssl;
    listen [::]:443 ssl;
    ssl_certificate         /etc/letsencrypt/live/alkarkhi.com/fullchain.pem;
    ssl_certificate_key     /etc/letsencrypt/live/alkarkhi.com/privkey.pem;
    server_name alkarkhi.com 51.195.152.242 2001:41d0:0800:2e90:6d72:2ffb:8267:0001;
    return 301 https://www.$server_name$request_uri;
    # SSL configuration
    listen 443 ssl default_server;
    listen [::]:443 ssl default_server;
    root /var/www/html;
    index index.html index.htm index.nginx-debian.html index.php;
    server_name www.alkarkhi.com;
	    if ($request_uri ~ "/index.html" ) {
		    rewrite ^(.*)/ $1/ permanent;
	    if ($request_uri ~ ^/(.*)\.html) {
		    return 301 /$1$is_args$args;
	    try_files $uri $uri.html $uri/ =404;
    error_page 404 /custom_404.html;
    location = /custom_404.html {
	    root /usr/share/nginx/html;
	    internal;
    location ~ \.php$ {
	    include snippets/fastcgi-php.conf;
	    # With php-fpm (or other unix sockets):
	    fastcgi_pass unix:/run/php/php7.3-fpm.sock;
    #	    # With php-cgi (or other tcp sockets):
    #	    fastcgi_pass 127.0.0.1:9000;
	    if ($request_uri ~ ^/(.*)\.php) {
    # concurs with nginx's one
    location ~ /\.ht {
	    deny all;
#server {
#	    listen 80;
#      listen [::]:80;
#	    server_name example.com;
#	    root /var/www/example.com;
# 	    index index.html;
#	    location / {
#		    try_files $uri $uri/ =404;
Don't worry @certb0t. @rg305 has the power :muscle: to fix your formatting.
And to undo a bad deletion too - lol
The first section seems to clash when "www" is used - by always adding another "www" to that.
	server_name alkarkhi.com www.alkarkhi.com 51.195.152.242 2001:41d0:0800:2e90:6d72:2ffb:8267:0001;
Otherwise I can't see wht they don't serve the same thing(s).
Since the (only) HTTP vhost is defined as the default, then you really don't need to match the server_name at all.
You can change:
To:
But you will then need to change:
To:
[and get a cert with both names on it - and then redirect from HTTPS to HTTPS://www]
[note: if you don't include both names on the cert, you can't accept HTTPS to both names]
I see that you have obtained several wildcard certs in the past...
Did you have to do them all manually?
[edit] please show the cert now in use with:
certbot certificates
As in literally?
I guess so. Most of these were only test certificates when I didn't know letsencrypt had a rate-limit
@rg305
Found the following certs:
Certificate Name: alkarkhi.com
Serial Number: 38cbc14f197af2e8760761c980f49105e00
Key Type: RSA
Domains: alkarkhi.com *.alkarkhi.com
Expiry Date: 2021-10-08 11:06:04+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/alkarkhi.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/alkarkhi.com/privkey.pem
btw the 89 days it because I renewed manually today
I edited the nginx config. Can someone verify if its right
Yes, any string will do.
Like:
server_name _;
Excellent!
You already have a wildcard cert; did you have to obtain it manually?
EDIT: Unfortunately, you had to renew it manually - we need to automate this (once and for all).
IPv6 continues to show a different reply:
Connection: close
Content-Length: 3592
And when you didn't/don't know LE has a test/staging system for this very purpose.
Do they actually? Where?
For example:
sudo certbot certonly --cert-name alkarkhi.com --nginx -d "alkarkhi.com,www.alkarkhi.com" --dry-run
The --dry-run causes certbot to use the staging environment.
The certonly command is included because --dry-run doesn't work with the run command (ridiculous, I know) with run being the default command when no other command is specified.
Do you actually need a wildcard certificate for your purposes? In the many hundreds of help cases that I've worked, I've found that almost no one actually needs a wildcard certificate based upon their circumstances. Wildcard certificates often require more work to maintain (as you can tell), can present security concerns, and reasonably offer no additional security over a non-wildcard certificate.
