DNS Provider Not Allowing TXT Records to Be Submitted Correctly - LetsEncrypt Validation Doesn’t Pass
slyy.testapp.win
./letsencrypt-auto certonly --agree-tos --renew-by-default --manual --preferred-challenges=dns
Please deploy a DNS TXT record under the name
_acme-challenge.slyy.testapp.win with the following value:
69jYN9xctvHD46eHWdF16tRBAfDReRtHFAmTyXl9QKE
Before continuing, verify the record is deployed.
it always failed,I have tried append TXT value to the _acme-challenge.slyy.testapp.win
I didn’t install it yet,I suppose to install tomcat 8.5
CentOS 7.5
What’s the exact error message you got?
Thank you
Failed authorization procedure. slyy.testapp.win (dns-01): urn:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.slyy.testapp.win
    Domain: slyy.testapp.win
    Type: None
    Detail: DNS problem: NXDOMAIN looking up TXT for
It’s a simple mistake due to a confusing user interface.
You added:
_acme-challenge.slyy.testapp.win.testapp.win. 589 IN TXT "69jYN9xctvHD46eHWdF16tRBAfDReRtHFAmTyXl9QKE"
So what you need to do, is just use this as the “host” in the DNS editor:
instead of the full string that Certbot tells you.
thanks ,Oh What a ridiculous mistake I have done,what a stupid mistake I have done,thank you very much
I have made it,thanks a lot
