DNS problem: NXDOMAIN looking up A for itmetommy.com
itsmetommy.com
./certbot-auto --apache
Failed authorization procedure. itmetommy.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for itmetommy.com
    Domain: itmetommy.com
    Type: connection
    Detail: DNS problem: NXDOMAIN looking up A for itmetommy.com
CentOS release 6.8 (Final)
/usr/sbin/httpd -v
Server version: Apache/2.2.15 (Unix)
Personal iMac at home running on VirtualBox.
no
See the difference? Look good :wink:
Wow. How did I miss that? Thank you so much. It works perfectly now. Thanks again @Osiris.
