DNS Manual Authentication Fails with NXDOMAIN
I am in the process of automating our certificate renewals. Many of the servers I’m validating lie behind a firewall and should remain private. In a previous post, I learned that I can validate a domain without opening any ports or IP addresses using the DNS challenge method, but it’s not working.
I ran certbot in manual mode with “certbot-auto -d dw.cameron.edu --manual --preferred-challenges dns certonly.” I added the appropriate DNS entries and tested them. In particular, I checked google’s DNS at 8.8.8.8 with nslookup to ensure that the TXT record is indeed accessible. It was accessible and correct. Yet, when I pressed enter to follow through to the next step, I get the following error.
Failed authorization procedure. dw.cameron.edu (dns-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.dw.cameron.edu
Can someone tell me what I’m doing wrong?
Thank you.
At the moment, “_acme-challenge.dw.cameron.edu.” really does return NXDOMAIN.
On the other hand, there is a TXT record for “_acme-challenge.dw.cameron.edu.cameron.edu.”.
_acme-challenge.dw.cameron.edu.cameron.edu. 600 IN TXT "bEoWKFO-rn2b76-QSr-USoveD3o2O3cs0OEKh-9soos"
Maybe Google Public DNS was returning older cached results? You need to double check how the DNS is configured.
Ah, I forgot to add the period at the end of the DNS entry name, so it tacked on an extra cameron.edu. Stupid me. I finally passed the validation. Thank you for your help.
