Determine which account certbot is using
My domain is: perception-staging3.kanjoya.com (this is one of the domains)
I ran this command: trying to find the command to run
It produced this output: none yet
My web server is (include version): centos 7
The operating system my web server runs on is (include version): centos 7
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.36.0
I inherited multiple certificates generated using let’s encrypt. I accidentally unsubscribed from the emails and now am trying to resubscribe using “certbot update_account -m new_email@host.com”. I found multiple let’s encrypt accounts.
How can I determine which account certbot is using? How can I make sure that is the same account that I used to receive emails from?
Thank you,
-Ryan
Each certificate that is under management by Certbot will have the account identifier listed in its renewal parameters file:
/etc/letsencrypt/renewal/example.com.conf
For example, it will look like:
account = d3b07384d113edec49eaa6238ad5ff00
This identifier correlates to the account directory in /etc/letsencrypt/accounts/. For example:
/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory/d3b07384d113edec49eaa6238ad5ff00/
You can then pass --server https://acme-v02.api.letsencrypt.org/directory --account d3b07384d113edec49eaa6238ad5ff00 to update_account to update it specifically.
I don't think there's a way. Perhaps updating all of the accounts that are in use by your certificate renewal parameters is the way to go.
Will all of the certificates managed by the account be listed under the [[webroot_map]] section of the /etc/letsencrypt/renewal/example.com.conf file?
Thank you for the certbot parameters for updating the specific account.
Each file in /etc/letsencrypt/renewal corresponds to one certificate. If you used --webroot to obtain that certificate and specified a distinctive webroot path for each domain (which isn't a requirement!), all of the domains would be listed in [[webroot_map]]. But in the general case, you could find out what the domains covered by the various certificates are by running certbot certificates (they're not guaranteed to be listed in /etc/letsencrypt/renewal configuration files at all, because Certbot always gets its list of domain names to renew by parsing the current version of the certificate on disk; the /etc/letsencrypt/renewal file is more about "how" than about "what").
