My domain is: portugalenfrancais.com
I changed my webserver (old hardware), and I transfered all of my websites
I simply transfered all of the files and databaes. From an external point of view, only IP has changed.
I'm running on Debian 11.
The "old" certificates where running good, but of course, without Certbot beeing installed, I can not renewal them. So I install certbot on my new webserver.
Everything is fine, the new certificates are issued, and I update my symlinks on vhosts files.
It don't work. It's like if apache wasn't following them, altough no error are issued no where that I know of.
Someone can help ?
Here's my config file :
<IfModule mod_ssl.c>
<VirtualHost *:443>
Protocols h2 h2c http/1.1
DocumentRoot /var/www/portugalenfrancais.com
ServerAlias portugalenfrancais.com *.portugalenfrancais.com francoportugais.com *.francoportugais.com lusitanie.fr *.lusitanie.fr
ServerName portugalenfrancais
ServerAdmin joriavlis@gmail.com
RewriteEngine On
RewriteCond %{HTTP_HOST} !^portugalenfrancais\.com$
RewriteRule (.*) https://portugalenfrancais.com$1 [L,R=301]
<Directory /var/www/portugalenfrancais.com>
Options -Indexes +FollowSymLinks +MultiViews
AllowOverride All
Order allow,deny
allow from all
</Directory>
SSLCertificateFile /etc/letsencrypt/live/portugalenfrancais.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/portugalenfrancais.com/privkey.pem
</VirtualHost>
<VirtualHost *:80>
RewriteEngine On
RewriteCond %{SERVER_PORT} ^80$
RewriteRule ^(.*)$ https://portugalenfrancais.com%{REQUEST_URI} [R=301,L]
RewriteCond %{SERVER_NAME} =portugalenfrancais.com [OR]
RewriteCond %{SERVER_NAME} =*.portugalenfrancais.com
</VirtualHost>
</IfModule>
Thank you !
rg305
March 28, 2022, 2:57pm
#3
Hi @joriavlis , and welcome to the LE community forum
Your config seems to be missing "SSLEngine ON":
curl -Ii http://portugalenfrancais.com:443/
Date: Mon, 28 Mar 2022 14:55:18 GMT
Server: Apache/2.4.53 (Debian)
Does this file exist?:
I found that on the logs:
portugalenfrancais:443:0 server certificate does NOT include an ID which matches the server name
(but I already also tried with a new certificate issued on this new webserver, it won't work either)
if I do https://portugalenfrancais.com , I just don't have a certificate...
rg305
March 28, 2022, 2:59pm
#5
Please show:
ls -l /etc/letsencrypt/live/portugalenfrancais.com/
cat /etc/letsencrypt/options-ssl-apache.conf | grep ngine
-rw-r--r-- 1 root root 692 Aug 30 2019 README
-rw-r--r-- 1 root root 1862 Feb 24 19:59 cert.pem
-rw-r--r-- 1 root root 3750 Feb 24 19:59 chain.pem
-rw-r--r-- 1 root root 5612 Feb 24 19:59 fullchain.pem
-rw-r--r-- 1 root root 1704 Feb 24 19:59 privkey.pem
SSLEngine on
rg305
March 28, 2022, 3:01pm
#9
9peppe:
certbot certificates
That might fail.
But shouldn't be required at this point.
rg305
March 28, 2022, 3:03pm
#10
This is what I see:
curl -Ii https://portugalenfrancais.com/
curl: (35) error:1408F10B:SSL routines:ssl3_get_record:wrong version number
No SSL.
But the cert files are there.
rg305
#11
I bet that we find:
80 > 80
443 > 80
Is there any NAT going on?
9peppe
March 28, 2022, 3:04pm
#12
I was thinking there might be more than one certificate for those names.
But yeah, apache is probably serving another virtualhost.
I think it might be time for sudo apachectl -t -D DUMP_VHOSTS
rg305
March 28, 2022, 3:06pm
#13
Agreed!
Apache is notorious for running at all cost.
If there are any default files in the enabled path, they may be causing this trouble too.
no NAT that I'm aware of.
I'm not a big pro of all of this, but it's a fresh new webserver, I just did the basics.
No SSL, but SSL Engine is On. What's going on @_ @
rg305
March 28, 2022, 3:07pm
#15
Show:
ls -l /etc/apache2/sites-enabled/
I have a lot of websites, all of them with the same issue, so the following is big:
total 0
lrwxrwxrwx 1 root root 35 Mar 1 12:30 000-default.conf -> ../sites-available/000-default.conf
lrwxrwxrwx 1 root root 37 Mar 28 10:47 13juillet.com.conf -> ../sites-available/13juillet.com.conf
lrwxrwxrwx 1 root root 41 Mar 27 22:07 auberydasilva.com.conf -> ../sites-available/auberydasilva.com.conf
lrwxrwxrwx 1 root root 36 Mar 27 22:21 benevale.com.conf -> ../sites-available/benevale.com.conf
lrwxrwxrwx 1 root root 46 Mar 28 09:53 caminhosdeportugal.com.conf -> ../sites-available/caminhosdeportugal.com.conf
lrwxrwxrwx 1 root root 39 Mar 27 14:24 cheveublanc.com.conf -> ../sites-available/cheveublanc.com.conf
lrwxrwxrwx 1 root root 35 Mar 27 22:29 da-silva.fr.conf -> ../sites-available/da-silva.fr.conf
lrwxrwxrwx 1 root root 34 Mar 27 22:44 dasilva.pt.conf -> ../sites-available/dasilva.pt.conf
lrwxrwxrwx 1 root root 34 Mar 27 22:34 e-jori.com.conf -> ../sites-available/e-jori.com.conf
lrwxrwxrwx 1 root root 34 Mar 27 22:46 e-kaki.net.conf -> ../sites-available/e-kaki.net.conf
lrwxrwxrwx 1 root root 35 Mar 28 09:58 ekonomia.pt.conf -> ../sites-available/ekonomia.pt.conf
lrwxrwxrwx 1 root root 41 Mar 28 09:49 emcadeamentos.com.conf -> ../sites-available/emcadeamentos.com.conf
lrwxrwxrwx 1 root root 34 Mar 27 22:49 helenos.pt.conf -> ../sites-available/helenos.pt.conf
lrwxrwxrwx 1 root root 35 Mar 27 22:54 inaciem.com.conf -> ../sites-available/inaciem.com.conf
lrwxrwxrwx 1 root root 42 Mar 27 22:58 monsieurqueijo.com.conf -> ../sites-available/monsieurqueijo.com.conf
lrwxrwxrwx 1 root root 34 Mar 28 10:12 parisii.fr.conf -> ../sites-available/parisii.fr.conf
lrwxrwxrwx 1 root root 38 Mar 27 23:02 philo-cafe.net.conf -> ../sites-available/philo-cafe.net.conf
lrwxrwxrwx 1 root root 46 Mar 28 10:56 portugalenfrancais.com.conf -> ../sites-available/portugalenfrancais.com.conf
lrwxrwxrwx 1 root root 40 Mar 27 23:08 static-media.com.conf -> ../sites-available/static-media.com.conf
lrwxrwxrwx 1 root root 35 Mar 28 10:31 tartines.fr.conf -> ../sites-available/tartines.fr.conf
lrwxrwxrwx 1 root root 41 Mar 28 09:07 transhumanismo.pt.conf -> ../sites-available/transhumanismo.pt.conf
lrwxrwxrwx 1 root root 50 Mar 28 09:12 transvision-conference.org.conf -> ../sites-available/transvision-conference.org.conf
lrwxrwxrwx 1 root root 34 Mar 28 10:45 vicedi.com.conf -> ../sites-available/vicedi.com.conf
VirtualHost configuration:
*:443 is a NameVirtualHost
default server 13juillet.com (/etc/apache2/sites-enabled/13juillet.com.conf:2)
port 443 namevhost 13juillet.com (/etc/apache2/sites-enabled/13juillet.com.conf:2)
wild alias *.13juillet.com
port 443 namevhost auberydasilva.com (/etc/apache2/sites-enabled/auberydasilva.com.conf:2)
wild alias *.auberydasilva.com
port 443 namevhost benevale.com (/etc/apache2/sites-enabled/benevale.com.conf:2)
wild alias *.benevale.com
port 443 namevhost caminhosdeportugal.com (/etc/apache2/sites-enabled/caminhosdeportugal.com.conf:2)
wild alias *.caminhosdeportugal.com
port 443 namevhost cheveublanc.com (/etc/apache2/sites-enabled/cheveublanc.com.conf:2)
wild alias *.cheveublanc.com
port 443 namevhost da-silva.fr (/etc/apache2/sites-enabled/da-silva.fr.conf:2)
wild alias *.da-silva.fr
port 443 namevhost dasilva.pt (/etc/apache2/sites-enabled/dasilva.pt.conf:2)
wild alias *.dasilva.pt
port 443 namevhost e-jori.com (/etc/apache2/sites-enabled/e-jori.com.conf:2)
alias joriavlis.com
wild alias *.e-jori.com
port 443 namevhost e-kaki.net (/etc/apache2/sites-enabled/e-kaki.net.conf:2)
wild alias *.e-kaki.net
port 443 namevhost ekonomia.pt (/etc/apache2/sites-enabled/ekonomia.pt.conf:2)
wild alias *.ekonomia.pt
port 443 namevhost emcadeamentos.com (/etc/apache2/sites-enabled/emcadeamentos.com.conf:2)
wild alias *.emcadeamentos.com
port 443 namevhost helenos.pt (/etc/apache2/sites-enabled/helenos.pt.conf:2)
wild alias *.helenos.pt
port 443 namevhost inaciem.com (/etc/apache2/sites-enabled/inaciem.com.conf:2)
wild alias *.inaciem.com
port 443 namevhost monsieurqueijo.com (/etc/apache2/sites-enabled/monsieurqueijo.com.conf:2)
wild alias *.monsieurqueijo.com
port 443 namevhost parisii.fr (/etc/apache2/sites-enabled/parisii.fr.conf:2)
wild alias *.parisii.fr
port 443 namevhost philo-cafe.net (/etc/apache2/sites-enabled/philo-cafe.net.conf:2)
wild alias *.philo-cafe.net
port 443 namevhost portugalenfrancais (/etc/apache2/sites-enabled/portugalenfrancais.com.conf:2)
alias portugalenfrancais.com
alias francoportugais.com
alias lusitanie.fr
wild alias *.portugalenfrancais.com
wild alias *.francoportugais.com
wild alias *.lusitanie.fr
port 443 namevhost static-media.com (/etc/apache2/sites-enabled/static-media.com.conf:2)
wild alias *.static-media.com
port 443 namevhost tartines.fr (/etc/apache2/sites-enabled/tartines.fr.conf:2)
wild alias *.tartines.fr
port 443 namevhost transhumanismo.pt (/etc/apache2/sites-enabled/transhumanismo.pt.conf:2)
wild alias *.transhumanismo.pt
port 443 namevhost transvision-conference.org (/etc/apache2/sites-enabled/transvision-conference.org.conf:2)
wild alias *.transvision-conference.org
port 443 namevhost vicedi.com (/etc/apache2/sites-enabled/vicedi.com.conf:2)
wild alias *.vicedi.com
*:80 is a NameVirtualHost
default server ns3075207.ip-217-182-174.eu (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost ns3075207.ip-217-182-174.eu (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost 13juillet.com (/etc/apache2/sites-enabled/13juillet.com.conf:23)
port 80 namevhost auberydasilva.com (/etc/apache2/sites-enabled/auberydasilva.com.conf:22)
port 80 namevhost benevale.com (/etc/apache2/sites-enabled/benevale.com.conf:22)
port 80 namevhost caminhosdeportugal.com (/etc/apache2/sites-enabled/caminhosdeportugal.com.conf:23)
port 80 namevhost cheveublanc.com (/etc/apache2/sites-enabled/cheveublanc.com.conf:23)
port 80 namevhost da-silva.fr (/etc/apache2/sites-enabled/da-silva.fr.conf:22)
port 80 namevhost dasilva.pt (/etc/apache2/sites-enabled/dasilva.pt.conf:23)
port 80 namevhost e-jori.com (/etc/apache2/sites-enabled/e-jori.com.conf:22)
alias joriavlis.com
port 80 namevhost e-kaki.net (/etc/apache2/sites-enabled/e-kaki.net.conf:22)
port 80 namevhost ekonomia.pt (/etc/apache2/sites-enabled/ekonomia.pt.conf:23)
port 80 namevhost emcadeamentos.com (/etc/apache2/sites-enabled/emcadeamentos.com.conf:24)
port 80 namevhost helenos.pt (/etc/apache2/sites-enabled/helenos.pt.conf:24)
port 80 namevhost inaciem.com (/etc/apache2/sites-enabled/inaciem.com.conf:22)
port 80 namevhost monsieurqueijo.com (/etc/apache2/sites-enabled/monsieurqueijo.com.conf:22)
port 80 namevhost parisii.fr (/etc/apache2/sites-enabled/parisii.fr.conf:23)
port 80 namevhost philo-cafe.net (/etc/apache2/sites-enabled/philo-cafe.net.conf:23)
port 80 namevhost portugalenfrancais (/etc/apache2/sites-enabled/portugalenfrancais.com.conf:28)
alias lusitanie.fr
port 80 namevhost static-media.com (/etc/apache2/sites-enabled/static-media.com.conf:23)
port 80 namevhost tartines.fr (/etc/apache2/sites-enabled/tartines.fr.conf:24)
port 80 namevhost transhumanismo.pt (/etc/apache2/sites-enabled/transhumanismo.pt.conf:23)
port 80 namevhost transvision-conference.org (/etc/apache2/sites-enabled/transvision-conference.org.conf:23)
port 80 namevhost vicedi.com (/etc/apache2/sites-enabled/vicedi.com.conf:22)
total 0
alias joriavlis.com
alias lusitanie.fr
alias joriavlis.com
alias lusitanie.fr
here it is
total 0
alias joriavlis.com
alias lusitanie.fr
alias joriavlis.com
alias lusitanie.fr
a lot of things...
here it is
total 0
alias joriavlis.com
alias lusitanie.fr
alias joriavlis.com
alias lusitanie.fr
mybigtext.txt (9.3 KB)
better this way ?
