much better
the transvision one is not pointing at my new host yet (and i don't try to issue a certificate for it for now)
Let's have a look at this file:
cat /etc/apache2/sites-enabled/000-default.conf
That does not matter. Only the 13juillet and portugalenfrancais should.
OMG
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =francoportugais.com [OR]
RewriteCond %{SERVER_NAME} =*.francoportugais.com [OR]
RewriteCond %{SERVER_NAME} =*.portugalenfrancais.com [OR]
RewriteCond %{SERVER_NAME} =portugalenfrancais.com [OR]
RewriteCond %{SERVER_NAME} =lusitanie.fr [OR]
RewriteCond %{SERVER_NAME} =*.lusitanie.fr
</VirtualHost>
[fingers crossed]
Check that SSLEngine is on in the default port 443 virtualhost:
default server 13juillet.com (/etc/apache2/sites-enabled/13juillet.com.conf:2)
I don't think apache can turn ssl on and off based on sni.
Let's have a look at:
cat /etc/apache2/sites-enabled/13juillet.com.conf
[edited - fingers crossed]
<IfModule mod_ssl.c>
<VirtualHost *:443>
Protocols h2 h2c http/1.1
DocumentRoot /var/www/13juillet.com
ServerAlias *.13juillet.com
ServerName 13juillet.com
ServerAdmin joriavlis@gmail.com
RewriteEngine On
RewriteCond %{HTTP_HOST} !^13juillet\.com$
RewriteRule (.*) https://13juillet.com$1 [L,R=301]
<Directory /var/www/13juillet.com>
Options -Indexes +FollowSymLinks +MultiViews
AllowOverride All
Order allow,deny
allow from all
</Directory>
</VirtualHost>
<VirtualHost *:80>
RewriteEngine On
RewriteCond %{SERVER_PORT} ^80$
RewriteRule ^(.*)$ https://13juillet.com%{REQUEST_URI} [R=301,L]
RewriteCond %{SERVER_NAME} =13juillet.com [OR]
RewriteCond %{SERVER_NAME} =*.13juillet.com
</VirtualHost>
</IfModule>
The 443 vhost is missing:
include /etc/letsencrypt/options-ssl-apache.conf
Yeah, you should add this line in there:
in the 13juillet file ? Or in the default file ?
13Juillet
In the 443 section.
Which it is missing a cert - LOL
And the rewrite will loop to itself.
THANK YOOUUUU !!
It worked !!
I would never find it by myself, you guys are incredible ^^ ...
So it was looping ?
But my question : why when I try to do it automatically, the vhost files are not edited ? Nothing happens...
Not looping [yet - that will happen when you add the cert to it].
It was using "SSLEngine OFF" [since it never set it ON] for the entire server.
Since the files in the enabled folder are processed alphabetically...
13.. comes before any of the words and was processed first.
And that one file "broke" your server.
so if I understand it correctly, my first vhost file is more important in the hierarchy than the "defaults" files ?
There was no "_default_
" (named) file for 443.
It will, because you have the same redirect in the 443 and 80 sections. You only want it in the 80 section.
If there is no 443 vhost, one will be created. If there is one, I don't know. Certbot might try and install the certificate but I'm not sure what will happen.
The first (alphabetically) IS the default file.
(this is why I have a 000_default.conf
file in my sites-enabled
It becomes the "default" file - not to be confused with files in that folder that have the name "default" OR "_default_
NOTE: Alphabetically "_" is seen before numbers (which are before letters).
