Issues when transfering servers
Hey guys,
I recently transfered to a new server and it has been so FUN (sarcasm). I have been having issues with certbot. Last time I transfered servers I really didn't have issues with certbot. Now all the mysql dependent websites aren't working and certbot is failing to properly provide certificates for my websites (i get the browser "attackers may be trying to steal your information" warning). It seems that I zipped the /etc/letsencrypt folder and transfered it to the new server. It doesn't like that the key files are not symlinks. I tried deleting the certificates and creating new ones, but I ran into a bunch of issues. Any advice? Thanks in advance.
My domain is: www.techmasterdesign.com, groupfinder.cc, wavebuddha.com
I ran this command: sudo certbot renew --dry-run
root@lenovo-server:/etc# sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/iamjulemusic.com.conf
Renewal configuration file /etc/letsencrypt/renewal/iamjulemusic.com.conf is broken.
The error was: expected /etc/letsencrypt/live/iamjulemusic.com/cert.pem to be a symlink
Skipping.
Processing /etc/letsencrypt/renewal/kineticskin.me.conf
Renewal configuration file /etc/letsencrypt/renewal/kineticskin.me.conf is broken.
The error was: expected /etc/letsencrypt/live/kineticskin.me/cert.pem to be a symlink
Skipping.
Processing /etc/letsencrypt/renewal/www.kineticskin.me.conf
Renewal configuration file /etc/letsencrypt/renewal/www.kineticskin.me.conf is broken.
The error was: expected /etc/letsencrypt/live/www.kineticskin.me/cert.pem to be a symlink
Skipping.
Processing /etc/letsencrypt/renewal/www.techmasterdesign.com.conf
Renewal configuration file /etc/letsencrypt/renewal/www.techmasterdesign.com.conf is broken.
The error was: expected /etc/letsencrypt/live/www.techmasterdesign.com/cert.pem to be a symlink
Skipping.
No simulated renewals were attempted.
Additionally, the following renewal configurations were invalid:
/etc/letsencrypt/renewal/iamjulemusic.com.conf (parsefail)
/etc/letsencrypt/renewal/kineticskin.me.conf (parsefail)
/etc/letsencrypt/renewal/www.kineticskin.me.conf (parsefail)
/etc/letsencrypt/renewal/www.techmasterdesign.com.conf (parsefail)
0 renew failure(s), 4 parse failure(s)
My web server is (include version): apache2
The operating system my web server runs on is (include version): Ubuntu 20
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.29.0
Do you still have access to the old server?
It went caput, only boots when it feels like it, but I still have the hard drive.
Well, it seems that when you zipped that folder, it didn't save any of the symlink information.
You can either:
  • access the hard drive and re-zip it with the proper symlinks
    OR
  • we can try to recreate them
To recreate them, you would remove the non-symlinks first and the use:
certbot update_symlinks
See: User Guide — Certbot 1.29.0 documentation (eff-certbot.readthedocs.io)
Thank you for your help fixing the symlinks. I ended up reinstalling linux as I fucked up by copying too much of the old linux filesystem.
This time around certbot worked almost flawlessly after i used a2ensite and copied over the sites-available. It says it created the certificates, however I am now getting the error "could not reverse map the HTTPS virtualhost to the original," could this possibly be a permission issue, or is certbot maybe missing a dependency?
That means there is no HTTPS vhost config that covers that name.
Usual Apache mischief :frowning:
Show:
apachectl -t -D DUMP_VHOSTS
sorry for the late replies, i've been slowly transfering everything :P.
root@lenovo-server:/home/george# apachectl -t -D DUMP_VHOSTS
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:80                   is a NameVirtualHost
         default server www.techmasterdesign.com (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost www.techmasterdesign.com (/etc/apache2/sites-enabled/000-default.conf:1)
                 alias techmasterdesign.com
         port 80 namevhost groupfinder.cc (/etc/apache2/sites-enabled/groupfinder.conf:1)
                 alias www.groupfinder.cc
         port 80 namevhost wavebuddha.com (/etc/apache2/sites-enabled/wavebuddha.conf:1)
                 alias www.wavebuddha.com
That looks good, but only has HTTP vhosts.
What shows?:
certbot certificates
root@lenovo-server:/etc/apache2/sites-enabled# certbot certificates
Found the following certs:
  Certificate Name: techmasterdesign.com
    Serial Number: 4716a2769850c9cf76abb5ec6d103d75d1e
    Key Type: RSA
    Domains: groupfinder.cc techmasterdesign.com wavebuddha.com www.groupfinder.cc www.techmasterdesign.com www.wavebuddha.com
    Expiry Date: 2022-11-28 03:11:15+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/techmasterdesign.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/techmasterdesign.com/privkey.pem
That's good too.
Which vhost config did you try to enable that failed?
I used certbot --apache to have it try to generate certificates for all domains. The output was this:
root@lenovo-server:/etc/apache2/sites-enabled# certbot --apache
1: groupfinder.cc
2: www.groupfinder.cc
3: techmasterdesign.com
4: www.techmasterdesign.com
5: wavebuddha.com
6: www.wavebuddha.com
(ref: /etc/letsencrypt/renewal/techmasterdesign.com.conf)
What would you like to do?
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for groupfinder.cc and 5 more domains
Certificate is saved at: /etc/letsencrypt/live/techmasterdesign.com/fullchain.pem
Key is saved at: /etc/letsencrypt/live/techmasterdesign.com/privkey.pem
This certificate expires on 2022-11-28.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Some rewrite rules copied from /etc/apache2/sites-enabled/groupfinder.conf were disabled in the vhost for your HTTPS site located at /etc/apache2/sites-available/groupfinder-le-ssl.conf because they have the potential to create redirection loops.
Successfully deployed certificate for groupfinder.cc to /etc/apache2/sites-available/groupfinder-le-ssl.conf
Successfully deployed certificate for www.groupfinder.cc to /etc/apache2/sites-available/groupfinder-le-ssl.conf
Some rewrite rules copied from /etc/apache2/sites-enabled/000-default.conf were disabled in the vhost for your HTTPS site located at /etc/apache2/sites-available/000-default-le-ssl.conf because they have the potential to create redirection loops.
Could not install certificate
**NEXT STEPS:**
- The certificate was saved, but could not be installed (installer: apache). After fixing the error shown below, try installing it again by running:
certbot install --cert-name techmasterdesign.com
Could not reverse map the HTTPS VirtualHost to the original
If i'm not mistaken, certbot creates the virtualhost ssl .conf files. If it doesn't, then i'm missing them and I should probably create them manually?
It created them, but did not enable them due to:
Let's have a look at those two files:
these two files don't exist:
I used a terminal command to have it create the symlinks from the sites-enabled folder, strange.
That doesn't add up... 2 + 2 = 2 [LOL]
Let's see:
ls -l /etc/apache2/sites-available/
cat /etc/apache2/sites-enabled/groupfinder.conf
cat /etc/apache2/sites-enabled/000-default.conf
There is an apache program for that:
a2ensite
sites/available:
-rwxrwxrwx 1 root root 1703 Sep 14 2020 000-default.conf
-rw-r--r-- 1 root root 6338 Mar 22 19:00 default-ssl.conf
-rwxrwxrwx 1 root root 432 Sep 13 2020 groupfinder.conf
-rwxrwxrwx 1 root root 431 Sep 13 2020 wavebuddha.conf
root@lenovo-server:/etc/apache2/sites-available# cat /etc/apache2/sites-enabled/groupfinder.conf
<VirtualHost *:80>
ServerName groupfinder.cc
ServerAlias www.groupfinder.cc
DocumentRoot /var/www/groupfinder
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.groupfinder.cc [OR]
RewriteCond %{SERVER_NAME} =groupfinder.cc
</VirtualHost>
root@lenovo-server:/etc/apache2/sites-available# cat /etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
	# specifies what hostname must appear in the request's Host: header to
	ServerName www.techmasterdesign.com
	ServerAlias techmasterdesign.com
	# error, crit, alert, emerg.
	# modules, e.g.
	#LogLevel info ssl:warn
	RewriteEngine on
	# for www.techmasterdesign.com
	RewriteCond %{SERVER_NAME} =www.techmasterdesign.com
	# for techmasterdesign.com
	RewriteCond %{SERVER_NAME} =techmasterdesign.com
</VirtualHost>
maybe a simple solution would be to copy the old ssl-le.conf files from my old install to the sites-available folder, and then rerun a2ensite?
Show that file here first [before enabling it].
