Issues when transfering servers
contents of 000-default-le-ssl.conf in sites-available of old working linux install:
<IfModule mod_ssl.c>
<VirtualHost *:443>
        # specifies what hostname must appear in the request's Host: header to
        ServerName www.techmasterdesign.com
        ServerAlias techmasterdesign.com
        DocumentRoot /var/www
        # error, crit, alert, emerg.
        # modules, e.g.
        #LogLevel info ssl:warn
        #enable SSL
        SSLOptions +StrictRequire
        SSLCertificateFile /etc/letsencrypt/live/www.techmasterdesign.com/fullchain.pem
        SSLCertificateKeyFile /etc/letsencrypt/live/www.techmasterdesign.com/privkey.pem
</VirtualHost>
</IfModule>
Those are redundant; As there are no other possible names that could be matched [and must match before they can even be compared].
Those need to be corrected to where the new cert is located [without the "www."]:
the only two files in the live folder are:
root@lenovo-server:/etc/letsencrypt/live# ls
README and techmasterdesign.com which looks like it contains the keys and such.
Don't touch those files.
Edit the file:
[remove the "www." from the cert paths]
when making the .conf file for the ssl-le, i should point to /etc/letsencrypt/live key yes?
Yes, they are here:
[shown by the output of certbot certificates]
Which are slightly different than what's in the file now:
Ok perfect. I just created that 000-default-le-ssl.conf file and copied from the old install, but removed the www. before in the path.
ready to enable it:
a2ensite 000-default-le-ssl.conf
Now presumably would be a2ensite 000-default-le-ssl.conf and then rerun certbot? THen if that works, repeat steps for other domains.
No need to run certbot anymore.
Just get apache to use the cert already obtained.
I just restarted apache, and checked port forwarding and DNS update for IP. Seems that I can only access the site from the local IP. Might just have to wait for the godaddy DNS server to update :p. I also wanted to say thank you in advance for all of your help <3
" This site can’t be reached
techmasterdesign.com refused to connect.
Try:
ERR_CONNECTION_REFUSED"
This is how 000-default-le-ssl.conf is supposed to look, right? Lol
<VirtualHost *:443>
        # modules, e.g.
        #enable SSL
        SSLCertificateFile /etc/letsencrypt/live/techmasterdesign.com/fullchain.pem
        SSLCertificateKeyFile /etc/letsencrypt/live/techmasterdesign.com/privkey.pem
</VirtualHost>
</IfModule>
That's a good file.
The port 443 problem is not a godaddy issue.
Address:  47.6.106.221
The router needs to port forward 443 as it does 80.
The firewall needs to accept 443 as it does 80.
port forwarding is good. I haven't messed with the linux firewall rules yet, that might be it.
just ran:
sudo iptables -I INPUT -p tcp -m tcp --dport 443 -j ACCEPT
sudo iptables -I INPUT -p tcp -m tcp --dport 80 -j ACCEPT
Still refusing connection, weird.
Reboot the entire Internet - LOL
I'm still getting "Connection refused" on port 443.
IPS?
Geolocation/fencing blocking?
I port forwarded 443 and 80 and added them to the iptables. Lol. Let me try a different terminal command for linux.
have you rebooted?
What shows?:
ufw status
