My domain is: coachmaster.co.uk and others
My web server is (include version): nginx 1.20.0
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: bitfolk
or certbot-auto --version
if you're using Certbot): 0.31.0 on old machine.
I am trying to test a rebuild of my server, while the old machine is still running.
I cannot auto-upgrade ubuntu, because the accumulated changes from 2010 (08?) are too many and the 18.04 to 20.04 upgrade breaks badly. It has come to the point where I have to rebuild the server in ubuntu 20.04. I can't test the webserver without the certificates, and I can't install via certbot because the new server is not on-line. I have discovered that the backup I have taken with rsnapshot does not include the symlinks!
So what symlinks must I re-create so that nginx is happy again.
Having set them up, with the latest restored files from the backup, should it work off-line, or will I have recertification woes?
I also note that I have been collecting csr/*.pem files on a daily basis, and keys/*.pem files even more frequently. What can I clear out to tidy up and regain some space?
Many thanks
Ian
