Could not issue an SSL/TLS certificate (Error: 403)
My domain is: jeetpharma.com
I ran this command: Tried issuing Let's Encrypt SSL via Plesk (added the DNS record corrrectly too).
My web server is (include version): Apache 2.4.29
The operating system my web server runs on is (include version): Ubuntu 18.04.5 LTS
My hosting provider, if applicable, is: 1&1 / ionos.ca
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk Obsidian 18.0.30
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.27.0 (Literally installed it for the purpose of answering this question)
Extra Notes: The domain was registered at ipage.com. Only putting this info because I have 8 domains from different registrars and this issue has never come up for any of the other 7 domains.
Any help will be appreciated. Thanks in advance!
Welcome to the Let's Encrypt Community, Ahil :slightly_smiling_face:
Given your experience, it looks like the previous challenge (that used the TXT record(s) you have created) may have failed, resulting in new TXT records being issued (that have been overlooked). I see this most often when not enough time has been allowed for the TXT records to propagate before trying to confirm the completion of the challenge(s).
Try again, being sure you have added the current TXT record(s). Before confirming the challenge(s), you can verify their existence using the following tool by entering the full challenge host (e.g. _acme-challenge.jeetpharma.com) in the box and clicking TXT:
Hey Griffin,
Thanks for your help. Guess I was just being impatient haha.
