Could not find block to include challenges
My domain is: nevarezfarmlabor.com
I ran this command: certbot --nginx -d nevarezfarmlabor.com -d www.nevarezfarmlabor.com
http-01 challenge for www.nevarezfarmlabor.com
http-01 challenge for nevarezfarmlabor.com
Certbot could not find a block to include challenges in /etc/nginx/nginx.conf.
My web server is (include version): nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18.04.4 LTS
My hosting provider, if applicable, is: digitalocean.com
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
What’s the output of nginx -T?
Here is the output.
Nothing more? Did you use the capital T? Because capital T should output all the parsed configuration files.
Apologies I used a lowercase t.
Here is the output.
configuration file /etc/nginx/nginx.conf:
include sites-enabled/*;
configuration file /etc/nginx/sites-enabled/nevarezfarmlabor.com:
events {
http {
            listen 80;
            server_name nevarezfarmlabor.com www.nevarezfarmlabor.com;
            access_log /home/NevarezFarmLabor/logs/nginx/access.log;
            root /home/NevarezFarmLabor/static;
            location = / {
              try_files $uri $uri/home.html;
Hm, strange. The certbot code to try and find the http block is rather simple. Perhaps certbot needs to have the http part in nginx.conf and you could move the include sites-enabled/*; statement inside that http block?
Are you sure this is all there is?
Your configuration is very unusual.
You should have a nginx.conf like this:
http {
  # more stuff that should be deleted
and then a sites-enabled/nevarezfarmlabor.com like this:
  listen 80;
  location = / {
  # more stuff at will
@Osiris that indeed was the issue. Using both your explanation and @9peppe example I relocated the http portion into nginx.conf and included sites-enabled. The certs were then issued successfully. I must have modified the nginx.conf file when initially tinkering with config. Thanks for your help with this @Osiris and @9peppe.
