Certbot could not find a block to include challenges in /etc/nginx/nginx.conf
My domain is: ordertest.dmcontact.com
I ran this command: certbot-auto --nginx -d ordertest.dmcontact.com
http-01 challenge for ordertest.dmcontact.com
Certbot could not find a block to include challenges in /etc/nginx/nginx.conf.
My web server is (include version): nginx/1.14.2
The operating system my web server runs on is (include version): Debian 10.5
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.7.0
I’ve been reading some others posts and I’m quite certain this is due to the nginx conf file (we have no issues with a similar server running Apache). I’ve tried using both certbot and certbot-auto, and they both return the same error.
I did find that I could create a manual certificate with a TXT record, revoke that certificate completely and then it would seem to get the certificate, but a dry-run shows it would fail for renewal.
It would seem that there is no vhost config that covers the name “orderroman.dmcontact.com”.
How is that name being served by this nginx system?
And please don't revoke unused, no longer needed, certificates.
Do you have both (certbot and certbot-auto) ?
The issue here is that particular subdomain is hidden. I have however created a test page at https://ordertest.dmcontact.com/ it should be easily reachable and it has the same error of being unable to find a block.
Yes I can use both of these, but the error is always the same.
Can you allow HTTP instead or catch the HTTP and redirect it to HTTPS?
Certbot is looking for an HTTP block for that name (not an HTTPS block) but it will follow a standard redirect.
This is my initial section of the conf file. Isn't this redirecting?
if ($host = ordertest.dmcontact.com) {
} # managed by Certbot
listen 80;
server_name ordertest.dmcontact.com;
location /.well-known {
        alias /var/www/ordertest.dmcontact.com/.well-known;
I do see it redirecting:
curl -Iki http://ordertest.dmcontact.com/.well-known/acme-challenge/test-file-1234
Server: nginx/1.14.2
Date: Thu, 13 Aug 2020 06:09:24 GMT
Content-Type: text/html
Content-Length: 185
Location: https://ordertest.dmcontact.com/.well-known/acme-challenge/test-file-1234
Please place a similar test text file in that challenge location and see if it can be reached via the Internet.
possible example:
echo "test" > /var/www/ordertest.dmcontact.com/.well-known/test-file-1234
You’ve shown the port 80 block; but is there a server block that listens on port 443 that covers the name “ordertest.dmcontact.com” ?
