Certbot could not find a block error
zones.dmcontact.com
certbot renew --dry-run
Attempting to renew cert (zones.dmcontact.com) from /etc/letsencrypt/renewal/zones.dmcontact.com.conf produced an unexpected error: Certbot could not find a block to include challenges in /etc/nginx/nginx.conf… Skipping.
My web server is (include version): nginx version: nginx/1.14.2
Debian 10.3
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
We’ve been using Certbot for a while now on various machines in our organization, so this one is a bit of a stickler. I can’t even find anything on Google about this error, “Certbot could not find a block”. Can anyone provide some insight into this one?
Hi @Canadian,
This error suggests that Certbot is having trouble parsing your nginx configuration. However, this can be a problem with Certbot’s understanding of nginx configurations rather than a sign that your configuration is invalid—the nginx configuration format is complex and poorly specified in places.
Would you like to share your nginx configuration here?
Alternatively, your version of Certbot is somewhat out of date (although it may be the latest packaged by your operating system); would you like to try a newer version of Certbot (maybe via the snap package or certbot-auto) to see whether a later release has already fixed this issue? Newer versions of Certbot will still read and work with your existing certificates and renewal configuration file.
Thank you, certbot-auto did the trick.
OK, well this is odd. the certbot-auto certainly installed the certificate. But when I renew the certificate through a dry-run, it still fails with same error. Surely I can’t be the only one encountering this issue?
