Site broke after installing through CertBot
My domain is: awakening.fun
sudo certbot install --cert-name awakening.fun
after running:
sudo certbot --nginx
and fixing this error:
Could not automatically find a matching server block for awakening.fun. Set the server_name directive to use the Nginx installer.
Deploying certificate
Successfully deployed certificate for awakening.fun to /etc/nginx/sites-enabled/default
nginx/1.18.0
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
Raspbian 64 bit
Yes
No
certbot 1.28.0
My Log if it helps:
2022-06-11 05:25:01,393:DEBUG:urllib3.connectionpool:http://localhost:None "GET /v2/connections?snap=certbot&interface=content HTTP/1.1" 200 97
2022-06-11 05:25:02,925:DEBUG:certbot._internal.main:certbot version: 1.28.0
2022-06-11 05:25:02,926:DEBUG:certbot._internal.main:Location of certbot entry point: /snap/certbot/2134/bin/certbot
2022-06-11 05:25:02,926:DEBUG:certbot._internal.main:Arguments: ['-q', '--preconfigured-renewal']
2022-06-11 05:25:02,926:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-06-11 05:25:02,972:DEBUG:certbot._internal.log:Root logging level set at 40
2022-06-11 05:25:02,975:DEBUG:certbot._internal.display.obj:Notifying user: Processing /etc/letsencrypt/renewal/awakening.fun.conf
2022-06-11 05:25:03,066:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x7f9d87fe80> and installer <certbot._internal.cli.cli_utils._Default object at 0x7f9d87fe80>
2022-06-11 05:25:03,173:DEBUG:urllib3.connectionpool:Starting new HTTP connection (1): r3.o.lencr.org:80
2022-06-11 05:25:03,363:DEBUG:urllib3.connectionpool:http://r3.o.lencr.org:80 "POST / HTTP/1.1" 200 503
2022-06-11 05:25:03,366:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/awakening.fun/cert1.pem is signed by the certificate's issuer.
2022-06-11 05:25:03,367:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/awakening.fun/cert1.pem is: OCSPCertStatus.GOOD
2022-06-11 05:25:03,376:DEBUG:certbot._internal.display.obj:Notifying user: Certificate not yet due for renewal
2022-06-11 05:25:03,378:DEBUG:certbot._internal.plugins.selection:Requested authenticator nginx and installer nginx
2022-06-11 05:25:03,392:DEBUG:certbot._internal.plugins.selection:Selecting plugin: * nginx
Description: Nginx Web Server plugin
Interfaces: Installer, Authenticator, Plugin
Entry point: nginx = certbot_nginx._internal.configurator:NginxConfigurator
Initialized: <certbot_nginx._internal.configurator.NginxConfigurator object at 0x7f9d884790>
2022-06-11 05:25:03,393:DEBUG:certbot._internal.display.obj:Notifying user:
2022-06-11 05:25:03,393:DEBUG:certbot._internal.display.obj:Notifying user: The following certificates are not due for renewal yet:
2022-06-11 05:25:03,394:DEBUG:certbot._internal.display.obj:Notifying user:   /etc/letsencrypt/live/awakening.fun/fullchain.pem expires on 2022-09-09 (skipped)
2022-06-11 05:25:03,394:DEBUG:certbot._internal.display.obj:Notifying user: No renewals were attempted.
2022-06-11 05:25:03,394:DEBUG:certbot._internal.display.obj:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-06-11 05:25:03,394:DEBUG:certbot._internal.renewal:no renewal failures
It looks like you just need to open up TCP port 443 on your server's firewall.
HTTPS traffic runs on a different port to HTTP traffic.
Hi @Dev4fuN, and welcome to the LE community forum :slight_smile:
That sounds a bit iffy.
Please show that default file.
And does this server only serve that one name?
Thank you, it worked :slight_smile: .
