Could not create client, connection refused
My domain is: visiongrp.in
I ran this command: I have no direct access. Site is hosted on Shared hosting.
It has DirectAdmin control panel installed on it.
My hosting provider, if applicable, is: PhotonHosting
I can login to a root shell on my machine (yes or no, or I don't know): No
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): DirectAdmin
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): I don't know
I'm getting below error while generating autossl. Even trying after 8 days it throws same error.
2021/03/11 06:21:19 Could not create client: get directory at 'https://acme-v02.api.letsencrypt.org/directory': Get "https://acme-v02.api.letsencrypt.org/directory": dial tcp 172.65.32.248:443: connect: connection refused
Certificate generation failed.
Please help me.Thank You.
Seemingly your hosting has trouble creating outbound connection. I recommend to contact your hosting provider: PhotonHosting with your problem.
Thank You sir,
I have contacted my hosting provider and it's working.
