Connection refused
My domain is: follotips.com
I ran this command: certbot --apache
    Domain: www.follotips.com
    Type: connection
    Detail: Connection refused
    Domain: follotips.com
    Type: connection
My web server is (include version): Apache/2.4.7 (Ubuntu)
The operating system my web server runs on is (include version):Ubuntu 14.04
My hosting provider, if applicable, is: arubacloud (VPS)
I can login to a root shell on my machine (yes or no, or I don’t know): YES
I have used certbot before I reinstalled ubuntu on my server. Now I want to make certbot to generate SSL.
I can’t reproduce any connectivity issues to your site over HTTP.
Maybe you have https/port 443 blocked in your firewall?
sudo ufw allow https
If your cloud provider has a firewall/security groups make sure it’s open there too.
