Connection refused error
Hello, Team
I'm trying to install certifications for several domains. But I have gotten connection refused error. Please see following details.
My domain is: corp-associe.jp, koshirophotography.com
certbot certonly --apache-server-root=/usr/local/apache2 --apache-vhost-root=/usr/local/apache2/conf/extra --apache-challenge-location=/usr/local/apache2/conf -d www.corp-associe.jp -d www.koshirophotography.com -d blog.koshirophotography.com -d nightview.koshirophotography.com
The operating system my web server runs on is (include version): RHEL 8
The version of my client is certbot 1.13.0
Here is additional comments that SSL port is enabled (firewall is no problem).
I had setup Let's Encrypt on CentOS8 successfully, but I'm trying to setup all my web site on Red Hat Enterprise Linux 8 version.
chmod 577 -R your site files
Hi, your port 443 (for https) is not open/responding but it looks like when validation was attempted your sites were redirecting to https.
@HardcoreGames, did you mean 755? I don't see why non-file-owners should get write permissions while the file owner shouldn't (which is implied by 577).
I have discussed this on several linux forums and chmod fixes them but I also chown them to www-data:www-data so that the owner is apache
Hi, All
Thank you so much your feedback. I have already changed directory owner to "apache". The folder permission has already been set to 755. So the user can access to the site. What else do I need to check??
Regards,
Hello again.
The problem has been fixed and I could get certifications.
Thanks for your support!
Regards,
Could you perhaps tell us, for if people find this thread through a search, what the solution was?
