Connection Reset By Peer
I have used it on another server with no problem for hundreds of domains, I run it with dns on two wildcard domains but this domain is not mine so I had to resort to the old way. but it is not working anymore.
I got a test in that path:
http://reg.sommerlopet.no/.well-known/acme-challenge/test
So any reason why it shouldn't be working?
reg.sommerlopet.no
sudo /var/lib/snapd/snap/bin/certbot certonly --apache -d reg.sommerlopet.no --dry-run -v
and
sudo /var/lib/snapd/snap/bin/certbot certonly --webroot -w /var/www/projects/prod/reg.sommerlopet.no -d reg.sommerlopet.no
Simulating a certificate request for reg.sommerlopet.no
http-01 challenge for reg.sommerlopet.no
Challenge failed for domain reg.sommerlopet.no
Domain: reg.sommerlopet.no
Type: connection
Detail: 78.41.124.36: Fetching http://reg.sommerlopet.no/.well-known/acme-challenge/nrGHVeyD79YBUnyEm6coJhuiSzwX_TaKWadrUAgyflo: Connection reset by peer
Apache/2.4.6
CentOS 7.9.2009
no
certbot 2.6.0
Yes, you are almost certainly affected by a Palo Alto Networks brand firewall. We have seen a lot of these since early last year.
You should talk to your network admins and have them change the Application Rule for "ACME protocol".
See an earlier post of mine for more info (link here )
You have the same "reset by peer" symptom as that thread. See below a request for that URL returns the expected 404 Not Found unless using a similar user-agent as the Let's Encrypt validation servers. (or a 200 OK when using your 'test' file)
curl -i http://reg.sommerlopet.no/.well-known/acme-challenge/Forum123 -A "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
HTTP/1.1 404 Not Found
Date: Sun, 14 May 2023 22:02:25 GMT
Server: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips
I previosly googled the problem and thought I've come across a good selection of possible explanations but none panned out, but your reply seems to be the at point.
I logged into another server in another network (which is running certbot just fine), and running that curl from there gave me the exact same response as you did, while running it while connected to the network gives me a regular 404. I've previously tested from another server, but not identifying as the certbot itself.
But according to the fact it works from my computer on our vpn but not outside when identifying as the certbot should indicate it is not a firewall on the server itself, but on the network. I forwarded this and my own confirmation test to the hosting supplier so I assume I know if this indeed solves it or not in a matter of minutes.. or hours, it is monday.
Thank you.
