Certbot renew failure connection reset by peer
Note - this has worked for a long time, but has suddenly stopped.
My domain is: doosan-ivusadev.com
certbot --force-renewal -d doosan-ivusadev.com
[root@ashdivacwebdev letsencrypt]# certbot --force-renewal -d doosan-ivusadev.com
Renewing an existing certificate for doosan-ivusadev.com
http-01 challenge for doosan-ivusadev.com
Challenge failed for domain doosan-ivusadev.com
    Domain: doosan-ivusadev.com
    Type: connection
    Detail: Fetching
    http://doosan-ivusadev.com/.well-known/acme-challenge/2DiGMBkTOTdM0CcWCQEs5UMn6hnMyr8xUWphCIIvZSs:
    Connection reset by peer
Apache/2.4.6 (CentOS)
CentOS Linux release 7.9.2009 (Core)
certbot 1.11.0
@ia0001671 Welcome to the community
We have seen similar problems recently and those have been caused by updates to a router / firewall which was blocking the acme challenge path from reaching the server. Attempts reaching your server fail in a similar way:
curl -I doosan-ivusadev.com/.well-known/acme-challenge
(note using the acme challenge path but without trailing slash for file name)
Date: Mon, 18 Apr 2022 19:30:42 GMT
Server: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips mod_fcgid/2.3.9 mod_perl/2.0.11 Perl/v5.16.3
Location: https://doosan-ivusadev.com/.well-known/acme-challenge
curl -I doosan-ivusadev.com/.well-known/acme-challenge/
curl -I doosan-ivusadev.com/.well-known/acme-challenge/ForumTest
Is the acme challenge path supposed to exist on the server? it's not there.
Not when you use the apache plug-in (or nginx one either). Temp changes are made directly to the server config and then removed.
In the case of missing files though it is unusual to get a 'reset by peer' response. That is more likely a firewall
Oh, once you resolve the acme challenge problem you might want to look at the cert chain Apache is sending. You are sending the leaf twice at the start of the chain. My guess is you are using fullchain.pem instead of chain.pem in the SSLCertificateChainFile setting in your (old) Apache VirtualHost
We were unable to find any firewall or intrusion prevention that would have caused this issue.
We ended up getting a vendor to set up DNS auth with a TXT record, which worked just fine.
certbot certonly --manual --preferred-challenges dns -d doosan-ivusadev.com
OK but you will need to repeat that every 60-90 days. The manual challenges cannot be auto-renewed.
Your current cert expires Jul18 and usually renews start 30 days before that to ensure time to resolve issues with your setup or Let's Encrypt problems.
Got it.
Thanks!
Even better is to automate the DNS challenge, e.g. by transfering your domains authorative DNS servers to one of the DNS providers Certbot has a DNS plugin for (User Guide — Certbot 1.26.0 documentation), such as Cloudflare (which is free as far as I know) or e.g. use acme-dns.
