Connection reset by peer on renewal
My domain is: areyvah.tv
I ran this command: certbot certonly -a webroot --webroot-path=/var/www/html --agree-tos -n -d www.areyvah.com -d areyvah.com --email support@unreel.me --force-renewal
http-01 challenge for www.areyvah.com
http-01 challenge for areyvah.com
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
Failed authorization procedure. areyvah.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://areyvah.com/.well-known/acme-challenge/9cBT5cSTLeG9TRQ_WMyh4KVvTmWO0zQ6Upsk4Um3pnM: Connection reset by peer
    Domain: areyvah.com
    Type: connection
    Detail: Fetching
My web server is (include version): nginx version: nginx/1.4.6 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 14.04.5 LTS
My hosting provider, if applicable, is: Digital Ocean
Additionally:
cetbot version 0.26.1
there is a redirect to https and prefixing with www (bot are going with 302)
/.well-known/acme-challenge contents are fully accessible from browser. There are no A or AAAA records in the respective NS-zone, because it’s a regular CNAME
server is listening 80,443 @IPv4, IPv6
Operational log is under the link
https://drive.google.com/open?id=1gADvCXvU4flFVw7B-GLMDHNiacXykFiI
areyvah.com.  300  A     198.211.118.227
areyvah.com.  300  AAAA  2a03:b0c0:0:1010::1423:6001
When connecting to http://areyvah.com/ over IPv6, I get a “Connection reset by peer” error. Over IPv4, I get a redirect to https://www.areyvah.com/.
Are you sure that IPv6 address is correct? Are the networking configuration, firewalls, and web server configuration okay?
Hi @nafas
there is another error: Checking
http://areyvah.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
https://www.areyvah.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
there is a http status 200, not 404. So there is not the validation file sent Letsencrypt wants to check.
there is another location for assets serving by nodejs (le.conf that included in every conf)
location ~ /.well-known {
try_files $uri $uri/ @node;
allow all;
log_not_found off;
root /var/www/html/;
location @node {
proxy_set_header Host $http_host;
proxy_set_header X-NginX-Proxy true;
proxy_pass http://unreel_me_backend;
proxy_redirect off;
I’ve been trying do disable ufw among all cluster hosts, issue still the same.
I think the issue is with WWW redirect, because right now I got cert with easily by invoking:
certbot certonly -a webroot --webroot-path=/var/www/html --agree-tos -n -d www.areyvah.com --email support@unreel.me
Then you must tell Certbot the root of this directory, so certbot can create the validation file under
/yourroot/.well-known/acme-challenge/validationfile
PS: Remove your ipv6 - AAAA entry.
Validationfiles are being created and served correctly, tried that several times. Anyways, thanks for suggestion, Herr Auer
There is no AAAA or A entries at all. Only CNAME and ALIAS
My own tool says - no.
https://check-your-website.server-daten.de/?q=areyvah.com
Letsdebug says - no:
AAAANotWorking
Error
areyvah.com has an AAAA (IPv6) record (2a03:b0c0:0:1010::1423:6001) but a test request to this address over port 80 did not succeed. Let's Encrypt will prefer to use AAAA records, if present, and will not fall back to IPv4 records. You should either ensure that validation requests to this domain succeed over IPv6, or remove its AAAA record.
Get http://areyvah.com/.well-known/acme-challenge/letsdebug-test: read tcp [2600:3c03::f03c:91ff:fea2:6a56]:56588->[2a03:b0c0:0:1010::1423:6001]:80: read: connection reset by peer
Trace:
@0ms: Making a request to http://areyvah.com/.well-known/acme-challenge/letsdebug-test (using initial IP 2a03:b0c0:0:1010::1423:6001)
@0ms: Dialing 2a03:b0c0:0:1010::1423:6001
@173ms: Experienced error: read tcp [2600:3c03::f03c:91ff:fea2:6a56]:56588->[2a03:b0c0:0:1010::1423:6001]:80: read: connection reset by peer
IssueFromLetsEncrypt
Error
A test authorization for areyvah.com to the Let's Encrypt staging service has revealed issues that may prevent any certificate for this domain being issued.
Fetching http://areyvah.com/.well-known/acme-challenge/z7N2YaxJNGmb4EWvVIpJShZx4hQOXk4xRcAVU3-vSDQ: Connection reset by peer
areyvah.com and www.areyvah.com have different IP addresses.
areyvah.com.          266   A      198.211.118.227
areyvah.com.          266   AAAA   2a03:b0c0:0:1010::1423:6001
www.areyvah.com.      1779  CNAME  areyvahtv.unreel.me.
areyvahtv.unreel.me.  1779  A      192.81.215.220
areyvahtv.unreel.me.  1779  AAAA   2604:a880:2:d0::4a54:a001
I still get a “connection reset by peer” error on areyvah.com's IPv6 address.
Let me check, it looks like NS1 balancer has sent the redirect to another cluster member. Thanks for the hint
Yes, both addresses are our, and both hosts have the same shared root folder for serving challenges. It’s weird, that second host doesn’t return requested data
Thanks a ton! I found a glitch it the default_server statement listen directive on the host - there was
listen [::]:80 ssl;
My apologies for disturbance. Have a good one!
