Connection reset by peer
I ran this command: /usr/bin/certbot renew
"identifier": {
"type": "dns",
"value": "apresentacao.avia.cge.ce.gov.br"
"status": "invalid",
"expires": "2022-04-06T09:35:01Z",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:connection",
"detail": "Fetching http://apresentacao.avia.cge.ce.gov.br/.well-known/acme-challenge/wCRYfIcF_SuR_lPlGg_DgKUqHtAo1VuT8keUulv4HGw: Connection reset by peer",
"status": 400
Processing /etc/letsencrypt/renewal/apresentacao.avia.cge.ce.gov.br.conf
Renewing an existing certificate for apresentacao.avia.cge.ce.gov.br
http-01 challenge for apresentacao.avia.cge.ce.gov.br
Challenge failed for domain apresentacao.avia.cge.ce.gov.br
^CExiting due to user request.
    Domain: apresentacao.avia.cge.ce.gov.br
    Type: connection
    Detail: Fetching
    Você tem mensagem nova de correio em /var/spool/mail/root
    nginx/1.20.1
    CentOS Linux release 7.9.2009 (Core
certbot --version
Can you open this URL? (It should either show something or a 404 error)
Is your firewall blocking connection from outside Brazil?
The validation servers are in the US and Europe.
I get 403 Forbidden:
curl -Ii http://apresentacao.avia.cge.ce.gov.br/.well-known/acme-challenge/wCRYfIcF_SuR_lPlGg_DgKUqHtAo1VuT8keUulv4HGw
HTTP/1.1 403 Forbidden
Server: nginx/1.20.1
Date: Wed, 30 Mar 2022 12:52:35 GMT
Content-Type: text/html
Content-Length: 153
I got connection reset by peer (in korea) so I guess some geoblocking there?
curl -v http://apresentacao.avia.cge.ce.gov.br/.well-known/acme-challenge/wCRYfIcF_SuR_lPlGg_DgKUqHtAo1VuT8keUulv4HGw
*   Trying 189.90.161.108:80...
* TCP_NODELAY set
* Connected to apresentacao.avia.cge.ce.gov.br (189.90.161.108) port 80 (#0)
> GET /.well-known/acme-challenge/wCRYfIcF_SuR_lPlGg_DgKUqHtAo1VuT8keUulv4HGw HTTP/1.1
> Host: apresentacao.avia.cge.ce.gov.br
> User-Agent: curl/7.68.0
> Accept: */*
* Recv failure: Connection reset by peer
* Closing connection 0
