Connection refused
Good Morning
Please, I don’t know what happens, the last time this happened to me, I had to install the server image again and restore all the websites
I have already deleted the ipv6, I have regenerated the DNS template to leave it by default, I have deleted the AAA ipv6 entries, I have deactivated firewalls, I don’t know what else to do
www.custommaniac.com
www.promolum.com
www.muchoregalo.com
www.pruebas.promolum.com (this is a new subdomain for test, it doesn’t have certificate and it gives me the same error when trying to create it)
Re:
No pudo emitirse un certificado SSL/TLS para custommaniac.com
Detalles
No ha podido emitirse el certificado SSL/TLS Let’s Encrypt para custommaniac.com . Error de autorización para el dominio.
Detalles
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/4556259185.
Details:
Type: urn:ietf:params:acme:error:connection
Status: 400
Detail: Fetching https://www.custommaniac.com/.well-known/acme-challenge/mma4en1XzQom-gRZC0O_sD7z2gfDer9ub-lTByI7gpU: Connection refused
My web server is (include version): Plesk Obsidian v18.0.27_build1800200508.17 os_Ubuntu 18.04
The operating system my web server runs on is (include version): Ubuntu 18.04.4 LTS
My hosting provider, if applicable, is: 1&1 IONOS
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk Obsidian v18.0.27_build1800200508.17 os_Ubuntu 18.04
Hi @RiderOne
I can fetch that url with my browser, there is a http status 404.
Try it one time again and share the output.
Hello, yes, the address, https://www.custommaniac.com/.well-known/acme-challenge/mma4en1XzQom-gRZC0O_sD7z2gfDer9ub-lTByI7gpU, give answer 404
But why?
https://www.custommaniac.com works perfectly
Hello, now I have tried again and it has given me this, as there are too many requests:
Detalles
Se ha excedido uno de los límites de uso de Let’s Encrypt para custommaniac.com .
Para más información, consulte el artículo de la base de conocimiento.
Detalles
Invalid response from https://acme-v02.api.letsencrypt.org/acme/new-order.
Details:
Type: urn:ietf:params:acme:error:rateLimited
Status: 429
Detail: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/
clicking the link returns this:
mma4en1XzQom-gRZC0O_sD7z2gfDer9ub-lTByI7gpU.u7sskBCH_lVJP9lPQd-Z7EG2MnW_wvWrpjTDVtFZG1Q
Detalles
Detalles
Details:
Status: 429
Now it returns again connection refused
The strange thing is that it happens to me with all the server domains
Then you have a blocking firewall, .htaccess or something else. I can see the url, so it's not a "not working webserver problem".
I have deactivated the firewall on the server, and it also happens to me in the test subdomain pruebas.promolum.com, in which there is neither .htaccess nor any other file. I'm going crazy looking for the solution.
now it works, I don’t know what happened but thanks, but only works in pruebas.promolum.com.
I cannot renew the certificates of:
carta-plus.es
cdvallobin.es
custommaniac.com
designtus.com
grupojdh.es
maquinasdecoseralonso.com
muchoregalo.com
promolum.com
tiendacustom.com
If you are on any aws service, you must open https port .
In lightsail, just go to networking tab and enable ssl port.
