Connection refused
Hello,
we renewed certificates for several years, but recently it started to return the error of connection refused. We checked ports: 443 and 80 are reachable. File is also reachable via web browser.
Any suggestions please?
My domain is: mystery-home-shop.com
We’re usually not managing networks so nothing suppose to change on firewalls unless hosting company change something
I ran this command: /root/opt/letsencrypt/letsencrypt-auto certonly --renew-by-default --email info@idventure.de -a manual -d mystery-home-shop.com
Challenge failed for domain mystery-home-shop.com
http-01 challenge for mystery-home-shop.com
    Domain: mystery-home-shop.com
    Type: connection
    Detail: Fetching
https://mystery-home-shop.com/.well-known/acme-challenge/KBbD3oeGv2broZwOwkRavuM3DA8xZiJRSdfoq2TEJqU:
Connection refused
Hi @shtirlic
you have ipv4- and ipv6 - addresses ( https://check-your-website.server-daten.de/?q=mystery-home-shop.com ):
mystery-home-shop.com A 88.99.87.195 yes 1 0
AAAA 2a01:4f8:c17:6a9c::2 yes
www.mystery-home-shop.com A 88.99.87.195 yes 1 0
But your http + ipv6 doesn't work:
http://mystery-home-shop.com/
88.99.87.195 301 https://mystery-home-shop.com/ 0.047 A
http://www.mystery-home-shop.com/
88.99.87.195 301 https://mystery-home-shop.com/ 0.046 E
2a01:4f8:c17:6a9c::2 -2 1.077 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it [2a01:4f8:c17:6a9c::2]:80
2a01:4f8:c17:6a9c::2 -2 1.097 V
https://www.mystery-home-shop.com/
88.99.87.195 301 http://mystery-home-shop.com/ 0.264 N
Certificate error: RemoteCertificateNameMismatch
88.99.87.195 200 0.856 I
2a01:4f8:c17:6a9c::2 -2 1.094 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it [2a01:4f8:c17:6a9c::2]:443
2a01:4f8:c17:6a9c::2 -2 1.093 V
http://mystery-home-shop.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
88.99.87.195 301 https://mystery-home-shop.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.047 A
Visible Content: Moved Permanently The document has moved here .
http://www.mystery-home-shop.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
88.99.87.195 301 https://mystery-home-shop.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.046 E
2a01:4f8:c17:6a9c::2 -2 1.060 V
Visible Content:
2a01:4f8:c17:6a9c::2 -2 1.080 V
Looks like your port 80 / ipv6 isn't configured or blocked by a firewall.
That's critical, because Letsencrypt prefers ipv6.
So
  • check your firewall settings and check, if ipv6 is configured (or)
  • remove the ipv6 AAAA entry, create a certificate, then fix your ipv6
Thank you @JuergenAuer, we will have a look into it!
