Connection Refused with Certbot
My domain is: pynamibia.org
I ran this command: certbot --apache certonly
It produced this output: (I do realize that my main problem is that the site doesn’t listen on 443, but I’m not sure what to do about it.)
1: pynamibia.org
blank to select all options shown (Enter ‘c’ to cancel):
tls-sni-01 challenge for pynamibia.org
Waiting for verification…
Failed authorization procedure. pynamibia.org (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Connection refused
    Domain: pynamibia.org
    Type: connection
    Detail: Connection refused
My web server is (include version): httpd (apache)
The operating system my web server runs on is (include version): Arch Linux
My hosting provider, if applicable, is: Linode
I can login to a root shell on my machine (yes or no, or I don’t know): Yes, with ssh
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): No, just ssh
Your domain offers IPv4 and IPv6 address records, but your server does not accept IPv6 connections to port 443.
Since IPv6 has higher precedence, the timeout occurs.
To fix that, either drop the IPv6 records or have a look into firewall rules which deny access via IPv6.
