Connection refused, Ports and firewall open
My domain is: justchaps.com (www.justchaps.com)
I ran this command: sudo etc/certbot-auto --apache
Failed authorization procedure. www.justchaps.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Connection refused, justchaps.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Connection refused
    Domain: www.justchaps.com
    Type: connection
    Detail: Connection refused
    Domain: justchaps.com
    Type: connection
Centos 6,
Apache
20i
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): None
My first time trying to use Let’s Encrpt on this server, and running the normal setup however I’m getting the error above. I’ve checked the ports and firewall and all seems to be fine. Any help debugging would be great.
Your ports may be open but it appears apache is not listening and that site is not bound on 443. You will need to modify your apache config for the site. Try this link for instructions. https://httpd.apache.org/docs/2.4/bind.html
