[solved] Certbot report "Connection refused"
I run:
certbot --apache -d www.collstrup.com -d collstrup.com -d nextcloud.collstrup.com -d nc.collstrup.com -d mail.collstrup.com  --test-cert
Output:
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
tls-sni-01 challenge for www.collstrup.com
tls-sni-01 challenge for collstrup.com
tls-sni-01 challenge for nextcloud.collstrup.com
tls-sni-01 challenge for nc.collstrup.com
tls-sni-01 challenge for mail.collstrup.com
Waiting for verification…
Failed authorization procedure. nc.collstrup.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Connection refused, mail.collstrup.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Connection refused, www.collstrup.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Connection refused, nextcloud.collstrup.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Connection refused, collstrup.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Connection refused
    Domain: nc.collstrup.com
    Type: connection
    Detail: Connection refused
    Domain: mail.collstrup.com
    Type: connection
    Domain: www.collstrup.com
    Type: connection
    Domain: nextcloud.collstrup.com
    Type: connection
    Domain: collstrup.com
    Type: connection
Firewall log indicate that ssl traffic is coming in doing the process
Oct 4 15:28:34 centos7-1 kernel: 443-firewalld-logIN=ens9 OUT= MAC=52:54:00:c6:db:74:30:91:8f:2a:83:e2:08:00 SRC=13.58.30.69 DST=77.215.239.148 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=9394 DF PROTO=TCP SPT=41276 DPT=443 WINDOW=26883 RES=0x00 SYN URGP=0
Oct 4 15:28:34 centos7-1 kernel: 443-firewalld-logIN=ens9 OUT= MAC=52:54:00:c6:db:74:30:91:8f:2a:83:e2:08:00 SRC=66.133.109.36 DST=77.215.239.148 LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=43474 DF PROTO=TCP SPT=48272 DPT=443 WINDOW=29200 RES=0x00 SYN URGP=0
Oct 4 15:28:34 centos7-1 kernel: 443-firewalld-logIN=ens9 OUT= MAC=52:54:00:c6:db:74:30:91:8f:2a:83:e2:08:00 SRC=34.213.106.112 DST=77.215.239.148 LEN=60 TOS=0x00 PREC=0x00 TTL=44 ID=50959 DF PROTO=TCP SPT=46432 DPT=443 WINDOW=26883 RES=0x00 SYN URGP=0
Oct 4 15:28:34 centos7-1 kernel: 443-firewalld-logIN=ens9 OUT= MAC=52:54:00:c6:db:74:30:91:8f:2a:83:e2:08:00 SRC=52.29.173.72 DST=77.215.239.148 LEN=60 TOS=0x00 PREC=0x00 TTL=54 ID=18137 DF PROTO=TCP SPT=42464 DPT=443 WINDOW=26883 RES=0x00 SYN URGP=0
System is Centos 7 minimal and public IP is bridged to the ens9 interface.
Using httpd24 and php 7 from SCL. Site is view able from many locations on port 80 (testet with geopeeker.com)
I have successfully used LE and certbot in the past so I am a bit confused by this problem.
/Anders
Hi @anderscollstrup,
The TLS-SNI-01 challenge uses port 443, not port 80. Making a connection to your site on port 443 does not appear to work.
For certbot --apache original issuance and renewals, your Apache does not have to be listening on port 443 already, but it needs to be possible to configure it to do so.
Hi schoen,
I am not sure I understand your answer. My server should accept 443. Check the firewall log I provided. It logs successful request on 443 (unless I misunderstand the log).
Firewall is open for both http and https
firewall-cmd --zone public --list-all
public (active)
target: default
icmp-block-inversion: no
interfaces: ens9
sources:
services: http https
ports:
protocols:
masquerade: no
forward-ports:
source-ports:
icmp-blocks:
rich rules
To confirm then I tried to stop firewalld and run certbot but I got the same result.
Apache is currently not configured with ssl … and do not listen to 443. Do I need to change that?
/Anders
Problem solved. I did install mod_ssl, but httpd24 need httpd24-mod_ssl.
I was a problem to uninstall mod_ssl since it was needed by certbot. Certbot do not play well with redhat scl.
/Anders
